chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Sat Jun 02, 2007 1:28 am Post subject: When to rivet rear fuselage |
We are up to 6-B-11B fuselage assembly which talks about taking the fuselage assembly off the bench and on to stands, to make it easier to work on.
My question is at what stage do you rivet the rear fuselage. The picture guides show that some pictures are riveted and some are still clecos.
I am thinking that I would want all the aft area tight and locked in with rivets before I took it off the bench??
over to you fellow builders..
Chris..
Michael Valentine
Posted: Sat Jun 02, 2007 5:03 am Post subject: When to rivet rear fuselage |
Chris - I am pretty much at the same point. I riveted the rear fuse (except the front of the longerons and the most forward two L-stiffeners) before I moved on to the firewall. So, at the same stage you are at, I have a riveted rear fuse, a riveted firewall, and an unriveted cabin floor. Unfortunately, because we are at the same stage I can't tell you if this will be a problem later! I will note that my version of the guide said to rivet the rear fuse and other builders have told me they pretty much riveted when they ran out of clecoes.
Michael in NH
On 6/2/07, chris Sinfield <chris_sinfield(at)yahoo.com.au (chris_sinfield(at)yahoo.com.au)> wrote: [quote]--> Zenith-List message posted by: "chris Sinfield" < chris_sinfield(at)yahoo.com.au (chris_sinfield(at)yahoo.com.au)>
Chris..
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Sat Jun 02, 2007 5:15 am Post subject: Re: When to rivet rear fuselage |
Go ahead and rivet except for anything on the upper longeron, the Z-angle on the forward end of the access hole (due to the step fairing) and the two most forward vertical L-angles (due to the baggage deck and step fairing). You will need to free up cleco's because the rest of the fuselage will get almost all the way built-up before you can think about riveting it.
Good luck!
_________________ David Gallagher
Cincinnati, OH area |
naumuk(at)alltel.net Guest
Posted: Sat Jun 02, 2007 5:45 am Post subject: When to rivet rear fuselage |
Chris-
When I was at Brampford a couple of weeks ago, there was a guy (I
believe his name was Mike) who built his entire plane in clecos in the
basement, tore everything apart to get it out, then riveted. Guess you can
theoretically wait forever.
Best compromise I've heard of is to put in just enough rivets to
stabilize the individual parts. If you know you're going to have to take
them out later on, put them in upside down for easy identification.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
dredmoody(at)cox.net Guest
Posted: Sat Jun 02, 2007 7:18 am Post subject: When to rivet rear fuselage |
Also, if you have a squeezer and dimple dies, set 4 - 6 flush-set A4 tack rivets on each side to hold the rear side skins to the top longerons. It really helps keep things trued up the way they were when rivetted.
Dred
davgray(at)sbcglobal.net Guest
Posted: Sat Jun 02, 2007 8:21 am Post subject: When to rivet rear fuselage |
I riveted my 601 XL basically from both ends towards the center and from
the bottom up. Leaving the turtle deck and the side skin overlap for last
without any problems.
My front top skin is removable nutplated #8 w countersunk machine screw
heads. This is a huge advantage during the wiring and troubleshooting phase
later.
Gary Ray
wjones(at)brazoriainet.co Guest
Posted: Sun Jun 03, 2007 3:03 pm Post subject: When to rivet rear fuselage |
Hello group ,I am at the stage where I am ready to take my fuselage off the table and put it on the saw horse .I have completed all the riveting with the exception of the top skins .The reason I did not take it off the table sooner was that I believe I had better control keeping it straight and level while riveting .My next move is to the saw horse ,then slide my spars into the center section spar to see if all fits well. leaving it on the table helps to alien all the parts but many times I was having to stand on a box to reach inside even at 6' tall . So far this has worked for me .DO NOT ARCHIVE
Wade Jones South Texas
601XL plans building
Cont. 0200
DaveG601XL
Posted: Sun Jun 03, 2007 4:39 pm Post subject: Re: When to rivet rear fuselage |
Wade,
I did the same thing and kept my fuselage on a table the whole time. It was a pain to access the bottom to drill, but it can be done with some extra thinking and planning involved. I am now ready to take mine off and get it on the gear. Building it per the plans with saw horses is probably the way to go, but I had been using my table to store parts and tools due to my limited space. I could not disperse those items to build on saw horses so I stuck with the table.
Good luck.
