Subaru owners
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List
larry(at)macsmachine.com
PostPosted: Wed Jun 06, 2007 3:55 pm    Post subject: Subaru owners Reply with quote
Hi Guys,
Some time ago, there was an article that featured a 601 with a Subaru
that had a bulkhead just inside the cowl that blocked air that would go
over the
engine. I'm not sure if any air was blocked below, but doubt it. Anyway,
there's been more than several days that I'd like to have been flying
with a nice
overcast but there were thin spots with rain and have been reluctant to
expose
my plugs and ignition to moisture of that sort. The fellow that did the
bulkhead
said his engine ran better and that he didn't have to worry about
drowning his
plugs in a downpour.
Sounds good, but how many of you have done the same
or experienced fouled plugs getting into the rain inadvertently.
I expect this protected his belt drive as well.
Any opinions or experiences among you on this?
- The Matronics Stratus-List Email Forum -
http://www.matronics.com/Navigator?Stratus-List
bryanmmartin
PostPosted: Wed Jun 06, 2007 4:35 pm    Post subject: Subaru owners Reply with quote
I put a sheet of aluminum just behind the cowl opening to deflect more air down over the oil pan in hopes of keeping my oil a little cooler. It seems to help a little. I don't know if it helps keep the rain off the plugs since I haven't flown in heavy rain.
On Jun 6, 2007, at 7:54 PM, LarryMcFarland wrote:
--> Stratus-List message posted by: LarryMcFarland <larry(at)macsmachine.com (larry(at)macsmachine.com)>
Hi Guys,
that had a bulkhead just inside the cowl that blocked air that would go over the
there's been more than several days that I'd like to have been flying with a nice
overcast but there were thin spots with rain and have been reluctant to expose
my plugs and ignition to moisture of that sort.  The fellow that did the bulkhead
said his engine ran better and that he didn't have to worry about drowning his
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
d3dw(at)sbcglobal.net
PostPosted: Thu Jun 07, 2007 2:38 am    Post subject: Subaru owners Reply with quote
Hmm. Never thought about that problem. However, when I have gotten into the rain on a few occasions, I never had any problem with plugs or ignition. the ignition components seem pretty well sealed to me. It is unlikely to penetrate the distributor, I think. Maybe a jacket or deflector around the tp-45s would ease the mind, depending where they are mounted. I think mine will stay dry mounted high on the firewall. I doubt it is a real problem, but I have never drown my plugs. I was more concerned about my prop tips with the composite edge, which I now cover neatly with foil tape.
don walker HDS-TD 405 hrs.
Bryan Martin <bryanmmartin(at)comcast.net> wrote:
[quote]I put a sheet of aluminum just behind the cowl opening to deflect more air down over the oil pan in hopes of keeping my oil a little cooler. It seems to help a little. I don't know if it helps keep the rain off the plugs since I haven't flown in heavy rain.
Hi Guys,
frank.hinde(at)hp.com
PostPosted: Thu Jun 07, 2007 8:09 am    Post subject: Subaru owners Reply with quote
Didn't fly much in the rain with my Soob Zodiac, but the RV is IFR and has seen a LOT of rain. it is also aircooled...Result is the wires and plugs get the direct onslaught of the water...Never even missed. and I use automotive leads and spark plugs.
As to the Soob, I would think as long as the distributor cap is in good condition and well sealed it should not be a problem.
Frank
Zodiac 400 hours
RV 7a (IO 360) 160 hours
From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Don Walker
Sent: Thursday, June 07, 2007 3:38 AM
To: stratus-list(at)matronics.com
Subject: Re: Subaru owners
Hi Guys,
http://www.matronics.com/Navigator?Stratus-List the Web href="http://forums.matronics.com">http://forums.matronics.com =========== [/b]
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List All times are GMT - 8 Hours
