mwcreek(at)frontiernet.ne Guest
Posted: Thu Jun 07, 2007 5:24 pm Post subject: JJN 80 Amp "Boltable" Fuse Source |
Does anyone know a good source for a JJN/JJS style 80 amp "boltable" fuse?
I'm wiring a 60 amp alternator per Z-22, but I can't seem to locate the
right fuse to wire in-line between the alternator and starter leads. I've
checked B&C and AC Spruce.
Mike C.
aurbo(at)ak.net Guest
Posted: Thu Jun 07, 2007 6:02 pm Post subject: JJN 80 Amp "Boltable" Fuse Source |
Thanks Mike. Those would work if they can be used in-line with a 4 awg
cable in about an 8-inch run. There isn't anyplace to mount an ANL type
base so the fuse must be strong enough in tension to survive in the high
vibration environment between the alternator and starter.
Searching the archives, Bob made reference to a JJN/JJS style "boltable"
fuse for that application.
Michel,
www.marineengineparts.com/shopsite_sc/store/html/page223.html
Is this the type of fuse you are looking for?
Mike
Mike C.
nuckollsr(at)cox.net Guest
Posted: Thu Jun 07, 2007 7:04 pm Post subject: JJN 80 Amp "Boltable" Fuse Source |
At 06:21 PM 6/7/2007 -0700, you wrote:
<mwcreek(at)frontiernet.net>
We discontinued that fuse when it proved less robust
mechanically than we would have liked. The recommended
replacement is the ANL series current limiters. Better
yet, consider the Littlefuse MEGA series fuses. See:
https://www.vtewarehouse.com/content/electromech/fuse/html/mega/megafuse.php
These are smaller and less expensive than the ANL devices.
Another option is the MAXI fuse which is also available with
an in-line holder at:
https://www.vtewarehouse.com/content/electromech/fuse/html/maxi/maxifuse.php
( "Physics is like sex: sure, it may )
( give some practical results, but )
( that's not why we do it." )
( Richard P. Feynman )
Joemotis(at)aol.com Guest
Posted: Thu Jun 07, 2007 7:52 pm Post subject: JJN 80 Amp "Boltable" Fuse Source |
Bob, as a long time lurker and a former 68F20/68F30 I would like to thank you for the personal knowledge you share so unselfishly.
The knowledge base that you have earned and so generously share is immeasurable in it's contribution to the advancement of Aviation. JJN/JJS indeed.
Joe Motis
I.B.E.W. Local 11 Special Skills Electrician
601 XL
See what's free at AOL.com.
Posted: Thu Jun 07, 2007 7:58 pm Post subject: JJN 80 Amp "Boltable" Fuse Source |
And it's=its when you proofread after the fact...
