Jerry Cochran
Joined: 10 Jan 2006 Posts: 111 Location: Wilsonville, OR
Posted: Thu Feb 09, 2006 3:10 pm Post subject: Icom A200-Help! |
Listers,
This question has been asked before by others, but replies are unclear. The
good folks at Icom have put an insufficient (IMO) "wiring diagram" in their
one sheet fold-out instructions. This is not like the ones we see on this
list, so they must think we are incapable of reading a "real" one.
Now that I've vented... Has anyone out there made a genuine one for this
radio that I can beg, borrow, steal? My setup is with two of these radios, but
with no audio panel.
This might have been a mistake, trying to save weight, time, panel space,
and $$$...
Jerry Cochran
Wilsonville, OR
nuckollsr(at)cox.net Guest
Posted: Thu Feb 09, 2006 3:46 pm Post subject: Icom A200-Help! |
At 06:01 PM 2/9/2006 -0500, you wrote:
Listers,
radios, but
and $$$...
Got a 'net address for their published schematic?
rv8ch
Posted: Fri Feb 10, 2006 5:06 am Post subject: Icom A200-Help! |
At 08:26 AM 2/10/2006 +0100, you wrote:
Mmmm . . . pretty cryptic instructions. I'm not sure how
the intercom feature works since they don't show how to hook
up a second headset/mic circuit. And for a radio that draws
2.6A in transmit, the power and grounding requirements are
a tad hyperbolic. They also call out requirements in the
text that are not repeated/illustrated in the drawings.
I'll study this a bit and see if I can unravel the "code" . . .
< with experiment. >
< --Lawrence M. Krauss >
gmcjetpilot(at)yahoo.com Guest
Posted: Fri Feb 10, 2006 8:36 am Post subject: Icom A200-Help! |
Jerry:
I agree with you that the diagram and instructions are not real clear, but I can help. What do you not understand. We can go over it pin by pin.
First I have to admit you set-up does not make a lot of sense to me. I don't understand the use of two ICOM's A200, no intercom or audio panel.
What kind of plane and use (VFR, IFR). I assume you have a one place plane because you really need a VOX intercom. The ICOM has an intercom but....
The built in intercom is really a super simple non-VOX button activated intercom that works independent of transmitting (ie either radio or intercom but not both at the same time, optional toggle switch needs to be installed.)
As far as audio panel, when you have two COMs it is hard to get around but can be done with some simple switches, but you really are limiting the usefulness of two COM's. There are some cheap used audio panels on eBay. You could make a simple switch to select which radio you want to transmit on and feed one radio audio thru the aux input of the other, making one the "master". This is non-standard wiring. I understand the need to listen to two radios at one time, ATC and ATIS for example. However the elegant solution is the Apollo SL40 with two receivers built in, which allows listening to two freqs at the same time. Since you can only transmit on one Freq at a time why two radios. In the old days it was nice to have two radios, so you could store two freqs, one in each radio, but two radios is less an advantage with Flip flop freq features of new radios. The nice thing is to listen to two freqs which the single Apollo SL40 does.
Don't get me wrong the ICOM is awesome, but do you really need two radios? If you do I would consider a audio panel. If you have a two place I would consider an intercom. PS engineering makes a cool little intercom, simple audio panel to handle just two coms.
I sent you an off line email and we can talk about it.
George (completed two ICOM A200 installations so I am an expert )
Subject: Icom A200-Help!
Listers,
and $$$...
Jerry Cochran
Wilsonville, OR
wrmaxwell(at)bigpond.com Guest
Posted: Fri Feb 10, 2006 3:29 pm Post subject: Icom A200-Help! |
I've done several instalations too but never 2 A200s together. I dont doubt
it can be done simply with switching but cant really see the usefulness.
The schematic in the handbook isn't of much use and mine contains an error
anyway. As for installing a single A200, I dont support the use of a toggle
switch. Much better to use a DPDT push-button switch as the PTT. Wire the
two headsets up to the intercom mic pin on the A200 using the NC switch
contacts but with the PIC microphone being switched to the Comms mic pin on
the A200 once the PTT is pressed. The co-pilot's mic is wired such that the
PTT activation grounds it, while also taking the PTT pin on the A200 to
ground, thus switching the radio from receive to transmit.
All that is probably a little hard to follow and probably demonstrates why
we use schematics? I have a smple schematic here somewhere, packed up among
my yet to be sorted papers. I can probably find it if that would help.
Bill
Bill Denton
Joined: 10 Jan 2006 Posts: 97 Location: Chicago, IL USA
Posted: Fri Feb 10, 2006 3:46 pm Post subject: Icom A200-Help! |
Has it been considered that the second radio might only be used for receive
only monitoring?
Posted: Sat Feb 11, 2006 5:16 am Post subject: Icom A200-Help! |
At 10:21 AM 2/11/2006 +1100, you wrote:
<wrmaxwell(at)bigpond.com>
switch.
What is the error you've identified?
Jerry Cochran
Posted: Sat Feb 11, 2006 10:51 am Post subject: Icom A200-Help! |
Thanks to all who have answered. I have two reasons for dual A200 Comms. One
is I simply like a backup, we do a lot of long cross-countries. Secondly,
when going into Bravo airspace, I like to have 4 freqs loaded and ready. My
wife, Susan, is a student pilot who likes to handle the radios, and this makes
it easy for both of us. We have a flying 6a also with two comms so are used to
it.. I have received offline help that looks very viable and will report
back, hopefully with a schematic.
BTW, after all the effort Bob K has gone to teaching all of us about proper
schematics, I find it ironic that some manufacturers don't follow the same
convention. Bob, will you please straighten these guys out???
Jerry Cochran
In a message dated 2/11/2006 12:03:51 A.M. Pacific Standard Time,
aeroelectric-list-digest(at)matronics.com writes:
Subject: Re: Re: Icom A200-Help!
--> AeroElectric-List message posted by: "Bill Maxwell"
Posted: Sat Feb 11, 2006 3:02 pm Post subject: Icom A200-Help! |
Been a while since I had looked at it Bob, so I dug the publication from its
hiding place. It is actually the Service Manual rather than the handbook
that comes with the radio, so it may not be applicable to it, unless the
schematic is repeated there. I no longer have my copy of the material that
was packaged with a radio.
Error is in schematic 5-1 and concerns the memory channel and frequency
exchange switching. As drawn, it calls out a 2 position rocker switch or
similar, with one position offering normally closed contact, the other
normally open. Correct switching actually requires a spring-loaded rocker or
separate momentary push switches, in other words both contacts normally
open, with switching action grounding the required position momentarily.
I reported this finding to Icom Australia and received a printed correction
slip immediately, indicating that it was a known fault. That was some 7-8
years ago so no doubt it has long been corrected in later reprints and as I
said, it may not occur in the documentation that ships with the radio
anyway.
I should have added to my previous post the obvious suggestion of using a
relay to achieve the required intercom/comms function. That is certainly
easier than trying to install a new PTT swithch with considerable wiring
hanging from it.
Bill- Original Message -----
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
To: <aeroelectric-list(at)matronics.com>
Sent: Sunday, February 12, 2006 12:06 AM
>doubt
>toggle
>switch.
Posted: Sat Feb 11, 2006 3:46 pm Post subject: Icom A200-Help! |
At 09:58 AM 2/12/2006 +1100, you wrote:
anyway.
hanging from it.
A real service manual! I'd love to get a copy.
The latest wiring on the ICOM website shows two normally
open, pull-downs to ground for those two functions.
I needed a break from some other things I was supposed to be
doing today and threw a little drawing package together. It's
posted at
http://www.aeroelectric.com/Installation_Data/IC-A200_Icom_Installation_Wiring.pdf
If folks would care to review it and ask any questions that are not
answered, suggest additional materials be added or have spotted errors,
I'd be delighted to get he feedback. I've already found a goof. I'd
intended
to show how to "dummy load" the speaker output with an inset on page
2. I also note that the real model number is IC-A200 which ought to be
fixed in several places.
Dee and I are off to dinner with some old friends who used to work with
us at Videmation when I was rummaging around in train wrecks instead
of building airplanes.
klehman(at)albedo.net Guest
Posted: Sat Feb 11, 2006 5:58 pm Post subject: Icom A200-Help! |
It wasn't obvious to me at first but the dimmer connection actually
feeds the incandescent panel lighting so it might make sense to feed
that pin from an instrument light dimmer if convenient.
Ken
Robert L. Nuckolls, III wrote:
>anyway.
>hanging from it.
posted at
intended
Posted: Sat Feb 11, 2006 7:41 pm Post subject: Icom A200-Help! |
I was an Icom dealer at the time I got my service Manual but I suggest that
you contact Icom US and ask for a copy. I suspect they will know who you
are and of your influence in our movement. If not, they would be well
advised to find out!
I'll take a look at your drawing after I clear this email backlog.
cheers
Bill
Posted: Sat Feb 11, 2006 7:48 pm Post subject: Icom A200-Help! |
Yes Ken, although I have never had the need to do so as none of my
installations were in Night VFR or IFR aircraft. I usually wired that pin
pair to the 13.8 voltt supply to provide an additional indication that the
radio was powered up.
Bill
Posted: Sat Feb 11, 2006 10:28 pm Post subject: Icom A200-Help! |
At 08:26 PM 2/11/2006 -0500, you wrote:
Ken
From what I understand about the dimmer from the instructions,
it's a bright/dim discrete. In other words, lighting goes to half
bright when a voltage is applied to the dimmer pin. Does anyone
have better data than that?
Posted: Sun Feb 12, 2006 5:12 am Post subject: Icom A200-Help! |
I thought that too until I powered it up and then opened the case to
check the light bulbs. My unit was purchased last April but I doubt that
there is more than one version of lighting. Not the greatest instructions.
Ken
>Ken
lehmans(at)sympatico.ca Guest
Posted: Sun Feb 12, 2006 9:55 am Post subject: Icom A200-Help! |
Ken
My experience with 2 Icom A200 installs (one TSO'd and one non-TSO'd) is
that the radio lighting will dim with the instrument panel light rheostat
control. It never occurred to me to connect it any other way.
Mike
Posted: Sun Feb 12, 2006 8:48 pm Post subject: Icom A200-Help! |
At 02:39 PM 2/12/2006 +1100, you wrote:
Take a peek at the dimming input. Can you confirm that it
simply drive panel lamps? Also, does it call out normal
input current to this pin?
Posted: Mon Feb 13, 2006 1:41 am Post subject: Icom A200-Help! |
That peek required a magnifying glass Bob, plus a bright light and a glass
of scotch.
The dimming circuit doesn't rate a mention in the specifications at all,
beyond a "+14v (input)" description in section 5-2 when describing the
Molex connector pins.
According to the schematic, the input flows through an LC filter, the coil
value unspecified but described as EXC-ELDR25C and is a component used in
several other parts of the schematic; the capacitor is 0.0047 uF. The input
is picked off at the L and C junction. Test voltages at that point are
called out as 13.5V both in Tx and Rx. It then leads to 2 "lamps" on the
Main Unit pcb, drawn as incandescent bulbs but described in the parts list
as LEDs, via an 8.2 ohm resistor. Those 2 are wired in parallel between the
tail of that resistor and ground. They backlight the front panel push
switches. Test voltages at the junction of the tail of the 8.2 ohm res and
the paralleled leds is 12.5V, both in Rx and Tx.
A branch before the 8.2 ohm resistor also feeds a further 6 "lamps", again
drawn as incandescent lamps but again described in the parts list as LEDs,
via an 18 ohm resistor. These 6 backlight the LCD display panel, wired 3 in
series, the 2 series networks then wired in parallel between the tail of the
18 ohm Res. and ground. These obviously backlight the LCD display on the
Front Unit. Test voltages at the junction of the led networks and the 18ohm
are called out as 10.0V on both transmit and receive..
Nothing furter mentioned anywhere but I hope this little helps. It seems to
me to be a fairly straightforward linear circuit, lending itself readily to
dimming by varying the input voltage below the 13.8 volt rail?
Bill
Posted: Wed Feb 15, 2006 4:42 am Post subject: Icom A200-Help! |
At 08:34 PM 2/13/2006 +1100, you wrote:
of scotch.
Agreed. Given the compactness of the package and what we
know about incandescent lamps, it's logical and likely that
the resistors serve as many as two purposes. (1) to balance
levels between the two lighting functions and (2) boost
life of the lamps. They're probably difficult to replace
and the prudent designer would do well to strive for very
long life. I'll modify my wiring diagram accordingly. Thanks for
the data dump!
