Dukes pump
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List
kshannon(at)seanet.com
PostPosted: Thu Feb 09, 2006 3:19 pm    Post subject: Dukes pump Reply with quote
Kevin Shannon
Superintendent
Severson Construction, LLC
Question for anybody using a Dukes pump: I am looking at a used Dukes boost
pump on ebay, the auction says 13v 24 psi/47 gph min and 31 psi max which
sounds like the one we need, my question is does it require an additional
check valve manifold type setup and closed loop return like the airflow
performance pump, or do you just simply install it in line and your good to
go? I can't find any specs for it on the Dukes web page.
Kevin Shannon
- The Matronics Rocket-List Email Forum -
http://www.matronics.com/Navigator?Rocket-List
fred.laforge(at)verizon.n
PostPosted: Thu Feb 09, 2006 6:06 pm    Post subject: Dukes pump Reply with quote
I ran a Dukes pump on my RV-4,180 hp with fuel injectoin, (Bendix) it
worked fine, no special plumbing or anything.
WiningsJ(at)aol.com
PostPosted: Thu Feb 09, 2006 7:35 pm    Post subject: Dukes pump Reply with quote
I am using a Dukes pump. It has a pressure relief and check valve built in
(real nice). It had been rebuilt shortly before I bought it. It had a bearing
seal start leaking. I replaced it with a new one and now it is leaking
again. I am going to find something else to use on my Rocket. Jim Winings #34.
317-718-3415
Jim Anglin
PostPosted: Fri Feb 10, 2006 8:36 am    Post subject: Dukes pump Reply with quote
I may be outta line here since you said Dukes, and I am sure you already know about AFP, but I used their setup between the selector and engine for my Rocket and it is beautiful. Has all the check valves, PRV, serviceable filter, hp rotary pump, and everything you need. A little pricey at +- $400, but hey - it's the fuel system - not where I want to cut corners for a few dollars.
Jim Anglin
HR II N144HR
DO NOT ARCHIVE
Jim Anglin
HR II N144HR
brinker(at)cox-internet.c
PostPosted: Fri Feb 10, 2006 9:54 am    Post subject: Dukes pump Reply with quote
When you refer to AFP you are refering to Airflow Perfomance ?
Randy
Jim Anglin
PostPosted: Sat Feb 11, 2006 2:54 pm    Post subject: Dukes pump Reply with quote
Time: 09:54:51 AM PST US
Subject: Re: Dukes pump
--> When you refer to AFP you are refering to -->-->-->Airflow
Perfomance ?
Randy
Yes - AFP is Airfow Performance
Jim Anglin
HR II N144HR
DO NOT ARCHIVE
Jim Anglin
HR II N144HR
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List All times are GMT - 8 Hours
