AW: Effectiveness of Van's Eyeball (LED) Cockpit Lights
romeo.victor(at)o2online.
PostPosted: Mon Jun 11, 2007 12:45 am    Post subject: AW: Effectiveness of Van's Eyeball (LED) Cockpit Lights Reply with quote
Hi Garey,
I mounted two of them as additional lights right and left into the roll over
bar. They work fine but I do not perform any kind of IFR night flying with
my plane. I use them in addition to two flexible Bosch lights.
There is no internal resistor in the lights so I installed one for both. If
I would do it a second time, I would omit the rheostat. They are not so
bright but sufficient to watch the instruments.
Stephan Servatius
80303
DEBRV
114 hrs
Has anybody mounted these lights - one on F804N-L and
another on F804N-R to be used as a general utility
light (map light) ?????. These will be mounted on
the "upper" portion of both F804N's, near the canopy
rail - which is angled down.
Plan to use the 2 of them simultaneously (one on each
side of the cockpit). Is a Dimming Pot actually
required to vary the light intensity or would just a
Toggle Sw be adequate (OFF or ON) which would only
give ONE brightness level (Full Bright) for night use
If you have used 2 of them simulatneously with a
Dimming Pot, what value did you use ???
Since I do not have one to experiment with:
a) Is there an internal resistor inside the Eyeball
Assy or is an
"external" resistor required for current
limiting ???
b) Do the Instruction Sheet give any info on
Voltage and Current
requirements for the LED ??
Thank you, Garey Wittich Santa Monica, CA
http://smallbusiness.yahoo.com/webhosting
