		369PL
				 Posted: Sat Jun 09, 2007 6:09 am    Post subject: 582 oil injection |
				I have a kitfox IV with a 582. The original builder removed the oil injection and premixed his fuel. I want to reinstall the oil injection. Which oil tank will fit under the cowl 582 side mount #881 465, $161.42 or
 582 end mount #88146582, $189.95. These are lockwood #s.  Or do you have to get a tank and make your own bracket. Also who sells the fuel header tank that goes behind the seat.
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		dosmythe(at)cox.net Guest
				 Posted: Sat Jun 09, 2007 6:44 am    Post subject: 582 oil injection |
				http://www.usplastic.com/catalog/product.asp?catalog%5Fname=USPlastic&category%5Fname=15034&product%5Fid=14979
 I just had to replace my original bottle.  The bottle supplied from Skystar
 is on the above site from US Plastics.  You will have to drill a hole in the
 bottom for a bulkhead fitting and modify the threads on the cap so it will
 vent.  John McBean was out of the bottles so I had to go to US Plastics.
 You can use these bottles but will have to fabricate a bracket.  Contact
 John McBean for the header tank.
 Don Smythe
 Don Smythe
		369PL
				 Posted: Sun Jun 10, 2007 5:19 am    Post subject: Re: 582 oil injection |
				Don I never had the original bottle. Which size did you use? Did you have to remove the cowling to refill the bottle? My cowling has a small door close to the back of the cylinder head of the engine.
				 Posted: Sun Jun 10, 2007 5:39 am    Post subject: 582 oil injection |
				It was the 64 oz / 2 qt bottle.  The location of the bottle is high on the
 firewall about center (just aft of the engine head.  If you have a small
 door located in this area it might just work.  Sounds like you don't have a
 standard Kitfox cowl where the top is removable?
 Don Smythe
