Deems Davis
Posted: Fri Jun 08, 2007 2:12 pm Post subject: Need some information CHT probs |
I'm wanting to install the CHT probes, but I can't find any information
as to what to torque them to. (oddly enough I found the info for
torquing the stainless steel bands that hold the EGT probs (45 in lbs).
Also do they get any sealant applied to the threads (anti-seize?)
Anybody got any insight here?
Deems Davis # 406
Baffling / Plenum / Engine Stuff
http://deemsrv10.com/
ScooterF15
Posted: Fri Jun 08, 2007 2:27 pm Post subject: Need some information CHT probs |
I put anti-seize on my CHT probes. I'm sure they'll need to be replaced someday and I wanted them to come back out. I don't remember if I had a spec for tightening those. I'll check next time I'm at the hangar if someone doesn't come up with the answer first.
-Jim
40134
In a message dated 6/8/2007 6:14:05 P.M. Eastern Daylight Time, deemsdavis(at)cox.net writes:
| Quote: | --> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net>
Deems Davis # 406
See what's free at AOL.com.
speckter(at)comcast.net Guest
Posted: Fri Jun 08, 2007 3:03 pm Post subject: Need some information CHT probs |
Torque is not critical. Antisieze is very helpful.
Gary
40274
AV8ORJWC
Posted: Sat Jun 09, 2007 6:44 pm Post subject: Need some information CHT probs |
Deems, Loctite has a Nickel based anti-seize which is good to 2400F
(which is what we use on the turbine sections). That will cover the
1400F that is encountered on the recip - exhaust tubes. I will grab you
a 1/4 oz. sample to try along with those white (non staining) Adels.
John Forsling can advise best on the torque value to install the EGT
probes into his ceramic coated tubes.
ScooterF15
Posted: Sun Jun 10, 2007 2:20 am Post subject: Need some information CHT probs |
Just to follow up: my AF2500 engine monitor installation manual specifies 25-30 in-lbs for the CHT probes.
-Jim
40134
In a message dated 6/8/2007 6:29:53 P.M. Eastern Daylight Time, JSMcGrew(at)aol.com writes:
| Quote: | I put anti-seize on my CHT probes. I'm sure they'll need to be replaced someday and I wanted them to come back out. I don't remember if I had a spec for tightening those. I'll check next time I'm at the hangar if someone doesn't come up with the answer first.
-Jim
40134
Deems Davis # 406
Jim "Scooter" McGrew
http://www.mit.edu/~jsmcgrew
Deems Davis
Posted: Sun Jun 10, 2007 7:03 am Post subject: Need some information CHT probs |
Thanks Jim, That and some anti-seize.
Deems
JSMcGrew(at)aol.com wrote:
| Quote: | Just to follow up: my AF2500 engine monitor installation manual
-Jim
40134
flywithowen(at)gmail.com Guest
Posted: Thu Jun 14, 2007 7:17 am Post subject: Need some information CHT probs |
