DME LED OUT (Narco)
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
pete(at)wort.org
PostPosted: Wed Jun 13, 2007 12:24 pm    Post subject: DME LED OUT (Narco) Reply with quote
Here's my question:
After doing a battery charge, I discovered to my dissapointment that the
DME head serving my Narco MK 12D is not working. The VOR tracking is
working, but the DME LEDs seem to be out. Of course, I can't tell if the
DME is functional, but not displaying. Anyone have a similar experience? I
know that some Narco elements have a sacrificial part (diode??) that is
supposed to prevent unit damage in the event of a voltage spike.
Please, no Narco-negative comments. The Garmin Fairy has not come to my
home, and it's not in his/her flight path (that I know of). I left the DME
on during the charging event. It's my fault. Any suggestions/Help are
welcome.
Any recommendations on a radio shop in Md. or Northern VA are also welcome.
PETE
Peter Langlois
Tiger N45319 (with relatively antique radios)
Leesburg, VA
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
douglist(at)macnauchtan.c
PostPosted: Wed Jun 13, 2007 2:06 pm    Post subject: DME LED OUT (Narco) Reply with quote
It would help to have a part number or two. I think the last DME that Narco made was the DME195 which is a fairly large blue box hidden somewhere. I have seen those beasts channeled by a MK12D but they have a readout that is a rectangle about 1 inch high and 3 inches wide. The lamps are not LED's but rather seven-segment incandescent lamps.
Can you listen to the DME code that is sent out every minute? That will tell you something about what's working and what is not.
--> From the U S of A, the only socialist country that refuses to admit it. <--
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
