Europa's grounded until inspected
sideslip(at)tiscali.co.uk
PostPosted: Fri Jun 15, 2007 9:39 am    Post subject: Europa's grounded until inspected Reply with quote
Please be aware that the PFA have issued a safety alert grounding all Europa's until inspected.
See www.pfa.org.uk/fd_latest_news.asp
Geoff Leedham
G-EOFS
rampil
PostPosted: Fri Jun 15, 2007 10:57 am    Post subject: Re: Europa's grounded until inspected Reply with quote
Sorry Chaps,
That would be UK only-based Europas are grounded
Europa owners in other countries should examine their tailplanes
as suggested for balance and then go about their business.
Ira N224XS
ptag.dev(at)tiscali.co.uk
PostPosted: Fri Jun 15, 2007 12:37 pm    Post subject: Europa's grounded until inspected Reply with quote
Ira,
With every respect intended….. IMHO you should be advising all our overseas brethren to not only check for balance but also for SLOP BETWEEN EACH TAILPLANE (Or STABILATOR as they call them.) and ensure it is dimensionally within permitted limits.
Regards (notwithstanding I’m not an official authority!)
Bob Harrison G-PTAG
rampil
PostPosted: Fri Jun 15, 2007 1:25 pm    Post subject: Re: Europa's grounded until inspected Reply with quote
Hi Bob,
Actually detection of control slop, or deadband is part of my preflight
inspection for each flight for all surfaces.
Bud Yerly and I were just reminiscing this afternoon about an XS that once
came into the shop with 1/2 inch play between stabilator sides
Ira N224XS
wdaniell(at)etb.net.co
PostPosted: Sun Jun 17, 2007 7:09 am    Post subject: Europa's grounded until inspected Reply with quote
Looking at the PFA rear attachment point bulletin. What is a “tap test”?
I have no slop between tailplanes but about � between trim tabs due to play in the hinges (as yet unused). Is this normal?
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of R.C.Harrison
Sent: Friday, June 15, 2007 15:36
Subject: RE: Re: Europa's grounded until inspected
Ira,
Bob Harrison G-PTAG
josok-e(at)ukolo.fi
PostPosted: Sun Jun 17, 2007 7:30 am    Post subject: Europa's grounded until inspected Reply with quote
Hi William,
You tap on epoxy-glass-sandwich surfaces. If it does not sound right, its
wrong.
It's a good method for checking delamination.
workshopcam http://www.okhuijsen.org/plane
http://www.europaowners.org/kit600
PostPosted: Sun Jun 17, 2007 9:45 am    Post subject: Europa's grounded until inspected Reply with quote
Ah ok it is what is sounds like...er... anyway I get it
thanks
