				 Posted: Sun Jun 17, 2007 5:06 pm    Post subject: Duckworks lenses cracking |
				Lighting question....
 I installed my lights according to instructions - strapping tape, 75
 degrees, and all...
 The lenses were intact through the entire manufacturing process.  I put them
 in fine.
 Today I was working on the wingtips and needed to remove the light
 assemblies and found that every screwhole had cracks.
 Anyone else have this issue?
 I'm kinda bummed - knowing that subsequent installations will be more
 difficult and won't be as tight.
 At a minimum, I need to order a new set of lenses...but I think I need some
 building advice when it comes to these things......
 Ralph Capen
		Tim Olson
				 Posted: Sun Jun 17, 2007 6:18 pm    Post subject: Duckworks lenses cracking |
				You sound like you didn't really install them the way the new RV-10
 Duckworks kits are made. With the new ones, there are no screw holes
 in the lenses at all, only in the retaining brackets.  Give Don a
 call and verify you have what you really need and he'll help get you
 on the right track.  There are no holes drilled in any of the lenses.
 Ralph E. Capen wrote:
  degrees, and all...
  them in fine.
  some building advice when it comes to these things......
  Ralph Capen
				 Posted: Sun Jun 17, 2007 7:07 pm    Post subject: Duckworks lenses cracking |
				The older ones are supposed to be drilled through.....on the 6's anyway...
 Now I know there's a better way - maybe a retrofit too.....
 I'll give Don a call...
		dasduck(at)comcast.net Guest
				 Posted: Mon Jun 18, 2007 10:33 am    Post subject: Duckworks lenses cracking |
				Hi Ralph,
 Tim is correct, the RV-10 lens has NO holes drilled in it.
 Give me a call,
 Don
				 Posted: Mon Jun 18, 2007 10:43 am    Post subject: Duckworks lenses cracking |
				503-543-2298 rings as invalid....got it from the RV Yeller pages....
 Better number?
 Ralph
		rvbuilder(at)sausen.net Guest
				 Posted: Mon Jun 18, 2007 11:26 am    Post subject: Duckworks lenses cracking |
				http://www.duckworksaviation.com/
