HawkerPilot2015
Posted: Mon Jun 18, 2007 10:00 am Post subject: Average yearly use. |
A friend is considering a Yak and was curious about the average time people are putting on their birds.
I put around 30 on mine last year but it was down for two months for a very extensive annual (and the premature birth of my daughter) and then about a month for a compressor problem.
Curious what you guys are putting on your crates.
steve.fox(at)mac.com Guest
Posted: Mon Jun 18, 2007 10:11 am Post subject: Average yearly use. |
Last year over 200 hrs
Curious what you guys are putting on your crates. [b]
phcarter(at)aol.com Guest
Posted: Mon Jun 18, 2007 10:17 am Post subject: Average yearly use. |
Have been between 100 hr and 200 hr a year.
This has been a bad year (work, maintenance, gas prices, life) ~50 hrs,
hoping to correct.
Biggs
david(at)mcgirt.net Guest
Posted: Mon Jun 18, 2007 10:21 am Post subject: Average yearly use. |
About 274 hrs last year on my 52 TW..
PeteAbbott(at)aol.com Guest
Posted: Mon Jun 18, 2007 10:23 am Post subject: Average yearly use. |
We put in about 45 hours, but our bird did not give birth.
Pete
N852GC
See what's free at AOL.com.
jonboede(at)hotmail.com Guest
Posted: Mon Jun 18, 2007 10:36 am Post subject: Average yearly use. |
1,280 hours in 5 years = ~ 250 /year
[quote]From: "Preston Carter" <phcarter(at)aol.com>
Reply-To: yak-list(at)matronics.com
To: <yak-list(at)matronics.com>
Subject: RE: Average yearly use.
Date: Mon, 18 Jun 2007 11:16:15 -0700
hoping to correct.
Biggs
HawkerPilot2015
Posted: Mon Jun 18, 2007 11:07 am Post subject: Re: Average yearly use. |
| flir47 wrote: | | About 26. I spend more time fixing it than flying it. |
Whose -50 did you buy?
For the rest of you...GOOD LORD!!! You guys own your own oil company?
Barry Hancock
Posted: Mon Jun 18, 2007 11:32 am Post subject: Re: Average yearly use. |
950+ in CJ's/Yak-50/-52 in the last 7 years...about 135 a year.
_________________ Barry Hancock
Worldwide Warbirds, Inc.
www.worldwidewarbirds.com
www.cj6.com |
ByronMFox(at)aol.com Guest
Posted: Mon Jun 18, 2007 11:39 am Post subject: Average yearly use. |
About 115 hours per year for the last 6 years in my CJ
See what's free at http://www.aol.com. [quote][b]
scott-p(at)texas.net Guest
Posted: Mon Jun 18, 2007 12:01 pm Post subject: Average yearly use. |
About 150 last year in my 55M.
Scott
ByronMFox(at)aol.com wrote:
| Quote: | About 115 hours per year for the last 6 years in my CJ
jan.mevis(at)informavia.b Guest
Posted: Mon Jun 18, 2007 12:09 pm Post subject: Average yearly use. |
That's a feeling I do share too (had about 40 flying hours last year, and a
multiple of that working on my 50; but every flying hour was a thrill ...).
HawkerPilot2015
Posted: Mon Jun 18, 2007 1:18 pm Post subject: Re: Average yearly use. |
| flir47 wrote: | | Tim Gagnon wrote: | | flir47 wrote: | | About 26. I spend more time fixing it than flying it. |
For the rest of you...GOOD LORD!!! You guys own your own oil company? |
The 50 was owned by some imbeciles in the past and, I have been working on it every weekend since I got it in April. Also apparently some A&P butcher’s got their hands on over the years too.
I’ll get the old girl fixed up and going soon. |
Seems like that can be an issue with -50's. Some take better care of their cars than they do their airplanes. I am no mechanic so I put some to good use over the past four years. They have returned my airplane to where it is now and I feel great about flying it.
Did you buy a green one perhaps that was located in CA?
Posted: Mon Jun 18, 2007 3:50 pm Post subject: Average yearly use. |
I have to admit that while I had one amazing period where I flew about
200 hours with almost NO maintenance issues, the rest of the time has
been spent writing articles for the YAK list on yet one MORE thing that
managed to break at the worst possible moment. The list seems almost
endless.... And still going.
Here's a little addendum that can be added to the paper I wrote on the
50 electrical system.
The Combined Device can be by-passed by applying 28 volts switched power
to the terminal marked like a CAPITAL "A" on the Combined Device itself.
This terminal is on the right hand side above the main contact terminal.
Applying 28 VDC to this terminal will close the MAIN CONTACTOR RELAY
inside of the combined device, connecting the generator to the aircraft
MAINS with no safety provisions what-so-ever. If you do this with the
MAIN BATTERY SWITCH turned on, and the engine either not running, or at
low idle, you will have reverse current flow to the generator limited
only by the size of the wire. Another word for this is called a "short
circuit". You will cause significant damage to the aircraft wiring and
"other stuff" if you make this mistake.
On the other hand, if you know what you are doing, and have verified
that the generator is indeed putting out a regulated 28 VDC, then doing
this will allow you to start, take-off and fly on the battery alone.
Then at cruise power, you apply 28 volts to this LARGE "A" terminal and
you will manually close the main contactor and charge your battery
in-flight.
This should by no means be considered a "normal procedure". However, if
you are stranded west of East Jesus with a generator light and no easy
way home, you can use this method by first testing the generator for
proper output, then putting in an emergency wire to this contact which
will allow you to have manual control of battery charging in order to
get you home. Of course when doing this, a close eye (as in a GLUED
EYE) should be focused on the aircraft voltage/charging current meter so
that the contactor can be opened at the first sign of irregular
indication.
Make sure you understand exactly what you are doing/risking before
attempting something like this. It's just like a fire-arm. It can
either save your bacon, or put a hole directly into your foot.
Mark Bitterlich
cjpilot710(at)aol.com Guest
Posted: Mon Jun 18, 2007 10:02 pm Post subject: Average yearly use. |
I put on about 125 to 150 hours per year. I presently have over 1300 hours on a M-14p since new. At this point she uses about 1qt of oil every 1.5 hours. At normal cruise I use 15g/h.
Â
Jim "Pappy" Goolsby
dabear(at)damned.org Guest
Posted: Tue Jun 19, 2007 3:15 am Post subject: Average yearly use. |
900 hours in 7 years in Yak-52s, CJ6As, and Yak-Chang's. (with 8 months
of no airplane)
128 hours a year average.
DaBear
Tim Gannon wrote:
