jtpackard(at)usfamily.net Guest
Posted: Tue Jun 19, 2007 8:06 am Post subject: VOR/GS Antenna |
Can anyone explain why some VOR "cat whisker" antennas are mounted with the
open end of the 'V' facing forward and some facing aft? Is there a
difference in reception quality and/or drag characteristics? Secondly, is
the polyester lamination over the steel for improved precipitation static
protection worth an extra $60? Thanks for any answers posted.
TPackard
--- http://USFamily.Net/dialup.html - $8.25/mo! -- http://www.usfamily.net/dsl.html - $19.99/mo! ---
rhdudley1(at)bellsouth.ne Guest
Posted: Tue Jun 19, 2007 8:35 am Post subject: VOR/GS Antenna |
TPackard,
I have been told that the orientation is a matter of preference though
the reception pattern ahead is slightly better with the tips pointing
forward. I think many prefer the appearance with the tips pointing aft.
(looks more aerodynamic:)
Richard Dudley
-6A flying (with tips pointing aft)
jtpackard(at)usfamily.net wrote:
with the open end of the 'V' facing forward and some facing aft? Is
there a difference in reception quality and/or drag characteristics?
Secondly, is the polyester lamination over the steel for improved
precipitation static protection worth an extra $60? Thanks for any
answers posted.
TPackard
earl_schroeder(at)juno.co Guest
Posted: Tue Jun 19, 2007 9:52 am Post subject: VOR/GS Antenna |
I heard once that the forward facing whiskers were to protect the eyes
of the public [and unaware pilots]...
the
bobf(at)feldtman.com Guest
Posted: Tue Jun 19, 2007 2:37 pm Post subject: VOR/GS Antenna |
shouldnt matter - precip/icing might be an issue/ appearance probably drives it. main thing is it should be horizontally polarized while the comm antennas should be vertically polarized
bobf
W5RF
On 6/19/07, jtpackard(at)usfamily.net (jtpackard(at)usfamily.net) <jtpackard(at)usfamily.net (jtpackard(at)usfamily.net)> wrote: [quote]--> AeroElectric-List message posted by: <jtpackard(at)usfamily.net (jtpackard(at)usfamily.net)>
TPackard
BobsV35B(at)aol.com Guest
Posted: Tue Jun 19, 2007 4:25 pm Post subject: VOR/GS Antenna |
Good Evening bobf and TPackard,
May I suggest that consideration be given to using blade antennas?
I have installed several sets with excellent results. They are relatively low drag, handle precipitation well, have no issues with ice and nobody has ever gotten an eye poked out by running into one.
While reception strength and pattern are not very important with modern radios, the blades do provide excellently balanced reception throughout the operating range. I generally have fed two VHF navigation receivers and two glide slope receivers from one set of blades. All in all, very happy with the results.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
In a message dated 6/19/2007 5:41:02 P.M. Central Daylight Time, bobf(at)feldtman.com writes:
| Quote: | shouldnt matter - precip/icing might be an issue/ appearance probably drives it. main thing is it should be horizontally polarized while the comm antennas should be vertically polarized
bobf
W5RF
On 6/19/07, jtpackard(at)usfamily.net (jtpackard(at)usfamily.net) <jtpackard(at)usfamily.net (jtpackard(at)usfamily.net)> wrote: | Quote: | --> AeroElectric-List message posted by: <jtpackard(at)usfamily.net (jtpackard(at)usfamily.net)>
TPackard
See what's free at AOL.com.
nuckollsr(at)cox.net Guest
Posted: Wed Jun 20, 2007 5:27 am Post subject: VOR/GS Antenna |
At 05:49 PM 6/19/2007 +0000, you wrote:
Distorting the classic linear dipole antenna by moving the ends
forward or aft on the aircraft will have two significant effects.
See:
http://www.tpub.com/content/neets/14182/css/14182_186.htm
The straight dipole in free space will exhibit strong and
equal responses to the broad sides of the dipole and very
sharp nulls (near zero response) to the ends. Obviously,
the "ideal" antenna would have equal and super responses
all the way around the compass . . . but we don't live in
a perfect world. Besides, in aircraft, we're MOST interested
in VOR stations that lie on our path of flight.
As soon as you distort the classic shape, the responses
to the broad sides will change . . . one gets weaker while the
other one gets stronger. This doesn't continue without
bounds . . . if you keep moving the free ends of the
antenna closer together, the antenna morphs from an
effective radiator/receptor of energy to a poorly
terminated transmission line with exceedingly high
SWR.
At the same time the braodside responses are distorting,
the nulls at the ends become less than "perfect" so
your ability to utilize VOR stations that lie off your
heading is improved.
Whether there is advantage to bringing the tips
forward or aft is mostly a matter of style. When
you're flying the Victor Airways, the charts depict
nav aid changeover points where it's recommended
that you stop navigating on the station behind you
and change to the station in front of you. This may
or may not be at the half-way point. There are
folks that spend many $killo$ of your tax money
to survey these routes with the goal of optimizing
performance based on signal strengths from the various
facilities. These surveys account for intermediate
obstructions and other effects of terrain.
Bottom line is that for 99.9% of the way YOUR airplane
is going to be used, the VOR antenna configuration
is not going to be a key component of your recipe for
success in completing the mission of the moment. I think
I'd base antenna selection on cost and appearance
in that order. Bob archer's wing tip antennas are strong
contenders in this market. Only if Bob's product proves
inadequate to YOUR tasks would I consider expanding the
field of consideration for which antenna to use. Obviously,
the v-whiskers are inexpensive and easy to install
and attach to a feed line. Consider using a BALUN to
improve on the interface between dipole and coax. See:
http://aeroelectric.com/articles/BALUN/Balun_Fabrication.html
For those members of the List interested in some of the
more esoteric aspect of our craft, cruise the website I
cited above. Stoke the Next/Back links for a broad and
well explained dissertation on antenna science. The same
site has a wealth of other data of interest for the
curious and motivated reader.
Posted: Wed Jun 20, 2007 7:15 am Post subject: VOR/GS Antenna |
At 08:25 AM 6/20/2007 -0600, you wrote:
I thought I recognized some of the stuff in the link
I cited. The Navy's Electricity and Electronics Training
Series are available from the a variety of websites including
my own. They are part of the downloadable CD materials which
you can access at:
http://www.aeroelectric.com/CD/
You'll need a high-speed internet connection to get these
documents with any reasonable dispatch. They are big. But
you can't beat the price for acquiring some excellent texts
on matters electronics. I taught out of earlier versions of
these documents at Great Lakes about 40 years ago.
If push comes to shove, you can order the CD from us . . .
or better yet, attend one of the seminars. You get the
CD for free. If you DO have a way to conveniently download
the CD, please duplicate and share with your local aviation
enthusiasts. Our charge for the CD is a nuisance-fee. It's
not our goal to turn a profit on the activity. The goal is
to maximize availability of the offered materials to any folks
who have an interest.
You can get the individual Modules for this series of
documents at:
http://www.phy.davidson.edu/instrumentation/NEETS.htm
Download, share, learn and enjoy . . .
Posted: Wed Jun 20, 2007 7:55 am Post subject: VOR/GS Antenna |
Thanks for the suggestion Bob.
One question though. I see the Comant CI-120 blade set for VOR/GS
Navigation sells for approx. $800. Do you know of any priced closer to the
"cat whisker' style?
Tom Packard
Super Rebel 90%(you know what that means!)
Posted: Wed Jun 20, 2007 8:15 am Post subject: VOR/GS Antenna |
Good Morning Tom,
No, I do not.
The price is a major detriment.
I was using Dorne Margolin units until they raised their price into the stratosphere. I then went to Comants and just last year installed a set of Sensor Systems blades. They have a stainless steel insert in the leading edge which MAY be helpful on unimproved strips. Don't know yet. Those were mounted below the stabilizer on a model E18S Twin Beech which frequents many out of the way landing strips.
The cost factor IS terrible, but they work great!
The "hidden in the wing tip" solution sounds great if it will work!
If that is not an option, I would pop for the blades.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
In a message dated 6/20/2007 10:57:56 A.M. Central Daylight Time, jtpackard(at)usfamily.net writes:
| Quote: | --> AeroElectric-List message posted by: <jtpackard(at)usfamily.net>
Tom Packard
Posted: Wed Jun 20, 2007 8:46 am Post subject: VOR/GS Antenna |
At 10:51 AM 6/20/2007 -0500, you wrote:
the "cat whisker' style?
Tom Packard
No, blade antennas are relatively simple with respect
to the antenna part . . . Bob archer could easily
fabricate a suitable pattern on a piece of copper clad
but a couple of 1/16th inch thick, fiberglas "flappers"
bolted to each side of your vertical fin would not draw much
praise for style. The expensive part of building a blade
antenna is to mold a stylistic, robust but LIGHT enclosure
around it. The tooling is not cheap, the process not trivial.
Hence, demand for such antennas has been decidedly low
in spite of the fact that they work well and look good.
A set of blades would also be heavier than a v-whisker
and this weight sets waaaayyy back on the moment arm for
your C.G. calculations.
Finally, given the inexorable fade of VOR as a primary
mode of navigation, it's my suggestion that you figure
out a way to get SOME VOR capability on board with a minimum
of expense and effort. I.e. don't bust yer buns to
achieve an optimized capability. VOR no longer
figures in the best-we-know-how-to-do. The v-whisker is
a mild compromise over blades in terms of performance.
The wing tip antennas are a bit more compromised yet
but sales of those devices is strong. I've not heard
of any one replacing them with another technology
'cause it doesn't perform well enough to accommodate
the mission.
Since I bought my first hand-held GPS in 1995, I've not
turned on a VOR receiver for any purpose other than
to demonstrate it to someone who is along for the ride
or to fiddle with while watching the ground go by.
( "Physics is like sex: sure, it may )
( give some practical results, but )
( that's not why we do it." )
( Richard P. Feynman )
