Flight Plan
deutscht(at)rhwhotels.com
PostPosted: Tue Jun 19, 2007 5:35 am    Post subject: Flight Plan Reply with quote
What are you flying guys using for your aircraft type when filing a flight plan? Duats doesn’t want to recognize RV10 as an aircraft type.
Tom Deutsch
#40545
Tim Olson
PostPosted: Tue Jun 19, 2007 6:15 am    Post subject: Flight Plan Reply with quote
Keep trying to use RV10 whenever you can, but some software/services
isn't up to speed on it yet. In those cases, use HXB and put
RV-10 in the comments. I think RV-10 is official, but just not
in all venues yet.
I'm also going to start putting "NOT A CIRRUS" in the comments, because
I had to listed to ATC keep calling me "CIRRUS 104CD" about a million
times this weekend, despite my repeated callbacks of "experimental".
Tom Deutsch
#40545
PostPosted: Tue Jun 19, 2007 6:40 am    Post subject: Flight Plan Reply with quote
Thanks Tim, I have seen an official FAA site somewhere where they
publish all the aircraft designators that ATC officially recognizes but
can't seem to find it now. It also gave climb and cruise specs for each
designated aircraft. It was interesting to see their take on performance
of all the different GA aircraft. (they even included the all the
military aircraft performances) Yesterday they kept asking me if I was
an RV8. I guess because of my N number. Duats says that if they don't
recognize the aircraft type just put in ZZZZ which I did and put
"aircraft type RV10") in the remarks. It didn't seem to help. I just
wondered if RV-10 would work.
Tom Deutsch N588RV
glastar(at)gmx.net
PostPosted: Tue Jun 19, 2007 7:08 am    Post subject: Flight Plan Reply with quote
Tom, goto
<http://www.icao.int/anb/ais/8643/index.cfm>
put in the manufactures box VAN'S and you get RV10
That is the official ICAO code, maybe Duats should update their database?
br Werner
Tom Deutsch N588RV
randy(at)romeolima.com
PostPosted: Tue Jun 19, 2007 7:17 am    Post subject: Flight Plan Reply with quote
If they dont' recognize RV10 then use "HXB" (Experimental, cruise 91-190
kts)
Randy Lervold
www.rv-3.com
