rvreynolds(at)macs.net Guest
Posted: Wed Jun 20, 2007 5:57 pm Post subject: RV-6A Paint Area |
On Jun 12, 2007, at 5:42 PM, Robin wrote:
| Quote: | I have one more question, How much paint does it take to cover an RV aircraft?
The paint area of a RV-6A is as follows.
Take the area and use the manufacture's recommended coverage for primer (please forgive the use of that "word") and finish coats and volia, you have the amount required, Do not forget to add in the amount that does not actually end up on the plane.
RV-6A Paint Areas (sq ft)Fuselage (Aluminum) ininSqFt670Fwd Side2481.513.6670Fwd Side2481.513.6671Fwd Top48175.7672Fwd Bott43329.6673Aft Side19.291.1212.1673Aft Side19.291.1212.1674Aft Top55.624617.8675Rear Top27407.5676Rt Bott2250.257.7677Lt Bott25.3850.258.9678Aft Bott16.771.128.2679Rear Bott1220.51.7Total118.4118.4Wing (Aluminum)Rt Wing w/o Fuel1049756.9Lt Wing w/o Fuel1049756.9Rt Wing Fuel Tank4839.513.2Lt Wing Fuel Tank4839.513.2140.1Rt Aileron483010.0Lt Aileron483010.0Rt Flap582610.5Lt Flap582610.540.9Total181.1Empennage (Aluminum)Vert Stab33419.4Rudder443410.4Rt Horz Stab453912.2Lt Horz Stab453912.233.8Rt Elevator48289.3Lt Elevator48289.328.1Total62.8Misc Fairings (Fiberglas)Spinner13062.1Upper Cowl345011.8Lower Cowl348018.9Nose Wheel 15003.5Nose Gear Leg2071.0Rt Main Wheel110006.9Rt Main Gear Leg25101.7Lt Main Wheel110006.9Lt Main Gear Leg25101.7Lt Gear Intersection10100.7Rt Gear Intersection10100.7Rt Wing Tip58.5249.8Lt Wing Tip58.5249.8Total75.5437.8Misc Fairings (Aluminum)Canopy FrameFwd FairingAft FairingRt Wing Root Fairing693.51.7Lt Wing Root Fairing693.51.7Rt Empanage Fairing-Upper30.04.00.8Lf Empanage Fairing-Uper30.04.00.8Rt Empanage Fairing-Lower22.020.3Lf Empanage Fairing-Lower22.02.00.3Total5.6443.5
