dj45
Posted: Wed Jun 20, 2007 8:00 am Post subject: fuel flow rate |
Can anyone tell me how fast gas should pass thru a fuel filter with just gravity, to supply a IO360?
The one I just tested would pass 60 gph, but I don't know if that will be enough for sure. (2g per 2 min.)
Getting this thing real close.
| - The Matronics Engines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
_________________ Do not archive
Dan Stanton
N801S CH 801
N226BS CH701
N24DS CH750 |
s_korney(at)hotmail.com Guest
Posted: Wed Jun 20, 2007 8:35 am Post subject: fuel flow rate |
Rule of Thumb....
10 gallons per hour , per 100 horse power...
60 gallons per hour should do it...
Best... Steve
----Original Message Follows----
Reply-To: engines-list(at)matronics.com
Subject: fuel flow rate
Date: Wed, 20 Jun 2007 09:00:31 -0700
Dan Stanton
90% done 90% to go
801, IO360
http://forums.matronics.com/viewtopic.php?p=119649#119649
Make every IM count. Download Messenger and join the i’m Initiative now.
It’s free. http://im.live.com/messenger/im/home/?source=TAGHM_June07
wingsdown(at)verizon.net Guest
Posted: Wed Jun 20, 2007 8:43 am Post subject: fuel flow rate |
If it isn't you should look into another engine. You could fly a P51 on
that kind of flow. My friends Cardinal with same engine typically burns
8.5 GPH in cruise and more in climb.
Rick
Float Flyr
Posted: Wed Jun 20, 2007 10:41 am Post subject: fuel flow rate |
Fuel flow is only one item that you have to attain for the operation of your
engine.... You have an IO which means injection. I think you will find out
you may need lots more pressure than a few inches of head for the fuel
injection... I haven't looked it up but I think it's well above twenty psi
and maybe well over 40 psi. I think carburetted models require between 3
and 6 psi pressure.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Wed Jun 20, 2007 10:43 am Post subject: fuel flow rate |
One other thing I forgot to mention is fuel filters should be installed
after the fuel pump... Pumps push fuel a lot better than they can suck it.
As a matter of fact you could say they suck at sucking!
Noel
[quote] --
Kitfox III-A
