Radios squawk ...literally
Jerry Cochran
PostPosted: Wed Jun 20, 2007 1:23 pm    Post subject: Radios squawk ...literally Reply with quote
Folks,
Away from home with very annoying problem... Dual Icom's, dual antennas,same problem either one. Hit transmit and I send out a squeal with voice. other pilots say it is LOUD!! Before I borrow tools and tear things apart, any suggestions? Only one PTT switch wired in at present. Sound like a bad ground somewheres?
Any and all help very appreciated.
Jerry Cochran
See what's free at AOL.com.
peter(at)sportingaero.com
PostPosted: Wed Jun 20, 2007 1:56 pm    Post subject: Radios squawk ...literally Reply with quote
Have you tried a different headset? Could be a microphone feedback problem?
Pete
befliegen(at)msn.com
PostPosted: Fri Jun 22, 2007 7:25 am    Post subject: Radios squawk ...literally Reply with quote
Try turning one of the transmitters off. If both are transmitting at
the same time (not by design, but for some unknown reason), the
frequencies "beat" against each other and the resultant squeal is the
difference between them.
Wayne
Jerry2DT(at)aol.com wrote:
Folks,
Jerry Cochran
<http://www.aol.com?ncid=AOLAOF00020000000503>.
Jerry Cochran
PostPosted: Sat Jun 23, 2007 8:34 am    Post subject: Radios squawk ...literally Reply with quote
Thanks Wayne,
Already tried that, no joy. Currently on a trip, so will pursue the matter when I get back to the hangar.
However, problem went away when copilot headset (brand new) is unplugged. Then both COMMS work fine, transmit and receive...
Jerry Cochran
Time: 08:25:43 AM PST US
