		DAVELEIKAM(at)wi.rr.com Guest
				 Posted: Thu Jun 28, 2007 8:42 pm    Post subject: QB tanks |
				So far so good.  Two QB tanks tested, no  leaks, never took them off the wings.  The final test will be to fill them  with fuel for engine testing and flight.  Hopefully  they remain sound.
  Just thought I'd let ya all know.
  By the way,  I simply installed the fuel  senders temporarily for the tests with the included gaskets, no pro-seal, and  they did not leak.  Must you use pro-seal for install, or is this just a  prudent practice?  I do plan on using the stuff, but the gaskets seem to  work well on their own.
  Dave Leikam
  40496
  About to start putting the guts and wires in my  wings.
		VHMUM(at)bigpond.com Guest
				 Posted: Thu Jun 28, 2007 11:11 pm    Post subject: QB tanks |
				Dave how did you test them ?
  Chris
  [quote]   ---
		AirMike
				 Posted: Fri Jun 29, 2007 3:21 am    Post subject: QB tanks testing |
				Yes - what was your leak test proceedure ???
  _________________ See you OSH '18
Q/B - sold. |
				 Posted: Fri Jun 29, 2007 4:03 am    Post subject: QB tanks |
				Dave,
 Some people are leaving out the gaskets completely and just using proseal and others are going the other extreme, using no proseal and just the gaskets.  Either way has benefits.  With just proseal, you will probably go longer without leaks, but if/when it becomes time to replace the senders, it will be more work to do so.  Using just the gaskets makes it much easier to change the senders, but the rubber will most likely dry out and crack and give you leaks sometime down the road.  Many are using the gaskets and putting anywhere from a little to a lot of proseal around them.  We have started just using the gaskets after putting a little proseal around the nutplates inside the tank.  I just tested a set of tanks and at first test there was a leak around one of the screws on one tank that was fixed by a quarter turn with a screwdriver.  Maybe a good combination if you are worried would be just the gaskets and then a bead around the outside of the gasket with proseal, and maybe a little proseal around the screws (but not on the head).
 Jesse Saint
 Saint Aviation, Inc.
 www.saintaviation.com
 Cell: 352-427-0285
 Fax: 815-377-3694
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam
  Sent: Friday, June 29, 2007 1:43 AM
  To: RV-10 matronics
  Subject: QB tanks
 Dave Leikam
 40496
   [quote]   [b]
		jwt(at)roadmapscoaching.c Guest
				 Posted: Fri Jun 29, 2007 4:56 am    Post subject: QB tanks |
				Jesse,
  I used the gaskets with  Fuel Lube. I have tested the tanks (even removed them to test the back side),  and they test ok. I used the balloon and soapy water method. Do you see any  potential problems with the gasket/Fuel Lube approach?
   John Testement
 jwt(at)roadmapscoaching.com (jwt(at)roadmapscoaching.com)
 40321
  Richmond, VA
 Paint prep and LOTS of misc  stuff
    From: owner-rv10-list-server(at)matronics.com  [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse  Saint
 Sent: Friday, June 29, 2007 8:03 AM
 To:  rv10-list(at)matronics.com
 Subject: RE: QB  tanks
 Dave,
 Jesse  Saint
 Cell:  352-427-0285
 Fax:  815-377-3694
   6/28/2007 5:57 PM
				 Posted: Fri Jun 29, 2007 5:27 am    Post subject: QB tanks |
				Did you use the lube on the threads of the screws or just on the face of the gasket?  I can’t say that I see any problem with it, although I am certainly no expert on Fuel Lube.  The main problem with just using the gasket, as I understand it, is that the rubber can dry out and crack.  I don’t know the affect of fuel lube on the rubber.  Others would be much more qualified to answer this.
 Jesse Saint
 Cell: 352-427-0285
 Fax: 815-377-3694
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement
  Sent: Friday, June 29, 2007 8:55 AM
 Jesse,
 John Testement
  40321
 Richmond,  VA
 Dave,
 Jesse Saint
 Cell: 352-427-0285
 Fax: 815-377-3694
  6/28/2007 5:57 PM  [quote]   [b]
				 Posted: Fri Jun 29, 2007 6:40 am    Post subject: QB tanks |
				I installed the senders as I stated, then installed  the quickdrain valves on the bottom of the wings.  Purchased a small brass  valve and necessary hardware from local store and installed that in the strainer  fitting.  I found a small rubber grommet and pushed that onto the vent  fitting.  Then put a balloon over the grommet and SLOWLY added  air from compressor turned way down to almost nothing through the open  valve.  Watched the balloon grow to about 14" dia.  Close  valve. (Ya think?!)  Sprayed dishsoap and water solution on fittings  and valve to be sure nothing was leaking and waited overnight.  Balloon  still at 14".  Sprayed soap on rivets just for grins and giggles, no  bubbles.  I am confident at this time there are no leaks.  Down the  road is another story, but I can't think of any more testing to do which would  identify any problem areas.
  I did at first have a small leak in the valve,  which I tightened and stopped the leak.  Also the balloon over the  vent fitting.  I just wrapped electrical tape around the neck tightly and  that stopped.
  I know some have found leaks in their QB tanks,  but I really did not expect any.  I have found the QB kits so far  to be of very good quality and am guessing Van's must test them before  install.  On to the wing guts.
  Dave Leikam
  40496
  QB wing guts
  [quote]   ---
				 Posted: Fri Jun 29, 2007 6:44 am    Post subject: QB tanks |
				I did not use anything on the screws with the  gasket.  I know, I thought they may leak also but they did  not.
  Dave Leikam
  [quote]   ---
				 Posted: Fri Jun 29, 2007 9:38 am    Post subject: QB tanks |
				I just put the Fuel Lube  on the gasket, not the screws. We'll see if it keeps the gasket from  drying.
 Sent: Friday, June 29, 2007 9:26 AM
 Do not  archive
 Jesse  Saint
 Cell:  352-427-0285
 Fax:  815-377-3694
 Jesse,
 John Testement
 40321
 Richmond, VA
 Dave,
 Jesse  Saint
 Cell:  352-427-0285
 Fax:  815-377-3694
 6/28/2007 5:57  PM 	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV10-List  | 	  01234
 5No virus found in this incoming message.  size=2>Version: 7.5.476 /
   6/28/2007 5:57 PM
		MauleDriver(at)nc.rr.com Guest
				 Posted: Fri Jun 29, 2007 11:22 am    Post subject: QB tanks |
				I recently tested my tanks using the balloon and soap and water method.
 No leaks found.
 I didn't have the nerve or knowledge to blow the balloon up to 14".  The
 warnings about not using too much pressure got my attention.  I just
 took up to where it the balloon starts to stretch if that makes any
 sense. How much pressure should be used here? how do you measure it?
 should I redo it and blow a balloon up to many inches?  Your
 thoughts/experience welcome.
 I didn't use anything on the gasket but I intend to use fuel lube on
 both the gasket and the threads.  It appears to be what fuel lube if for
 - a non-drying, petrochemical resistant sealant for fittings that have
 fuel trying to leak out.  I guess pro-seal sounds like the samething
 except it would seem to get hard over time.
 Bill "installing wires for autopilot servo and LED position lights in
 wings" Watson
 John Testement wrote:
  	  | Quote: | 	 		   I just put the Fuel Lube on the gasket, not the screws. We'll see if
  [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Jesse Saint
  *Sent:* Friday, June 29, 2007 9:26 AM
  *To:* rv10-list(at)matronics.com
  *Subject:* RE: QB tanks
  Jesse Saint
  jesse(at)saintaviation.com <mailto:jesse(at)saintaviation.com>
  www.saintaviation.com <http://www.saintaviation.com>
  Cell: 352-427-0285
  Fax: 815-377-3694
  [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *John
  Testement
  *Sent:* Friday, June 29, 2007 8:55 AM
  Jesse,
  John Testement
  jwt(at)roadmapscoaching.com <mailto:jwt(at)roadmapscoaching.com>
  40321
  Richmond, VA
  *Sent:* Friday, June 29, 2007 8:03 AM
  Dave,
  not on the head).
  Jesse Saint
  Cell: 352-427-0285
  Fax: 815-377-3694
  6/28/2007 5:57 PM
  *http://www.matronics.com/Navigator?RV10-List*
  *http://forums.matronics.com*
  6/28/2007 5:57 PM
				 Posted: Fri Jun 29, 2007 8:47 pm    Post subject: QB tanks |
				I blew the balloon up to what I thought would be easy to measure and detect
 shrinkage.  No special size or pressure.  I would think the pressure to
 inflate a balloon would not harm the tanks at all and the balloon would
 burst way before any damage would be done to the tank.  Now I know even a
 moderately small amount of vacuum could crush the tanks.  I believe sea
 level AP is about 14.5 psi?
 Dave Leikam
 40496
				 Posted: Fri Jun 29, 2007 9:13 pm    Post subject: QB tanks |
				The size of the balloon can shrink or grow with temperature change.  I don't think the size of the balloon matters as much as it holding its pressure.  Just IMHO.  Also, a small balloon will pop before hitting 14".  Size doesn't matter much here, guys, as long as it is consistent.
 Jesse Saint
 Saint Aviation, Inc
 352-427-0285
 Leather interior kit for the RV-10 -
 www.saintaviation.com/interior
