andynfultz(at)bellsouth.n Guest
Posted: Fri Jun 29, 2007 12:03 pm Post subject: Pre Cover and Finish Thoughts? |
Good afternoon guys. I'm about to embark on what I hope to be the final big
step in the build process. I THINK I'm ready to cover and paint my project.
My question to you is this. Are there any, &(^%(&^%., I wish I had done
that before I covered, items I need to make sure I have done. I can't seem
to think of any more excusses not to go ahead. Just looking for
suggestions. Thanks.
Andy Fultz
AVID Speedwing (Extended)
STRATUS EA-81
Starkville, Mississippi
skwgn(at)comcast.net Guest
Posted: Fri Jun 29, 2007 12:57 pm Post subject: Pre Cover and Finish Thoughts? |
I picked a 3-color paint scheme and that was a ton of work. Doing it again
I'd only use 2 colors. Be prepared that covering and painting is 1/2 to
2/3rds of the total effort to complete a project. It was 2/3rds for me.
-Bob
Kitfox 3
akflyer
Posted: Fri Jun 29, 2007 1:31 pm Post subject: Re: Pre Cover and Finish Thoughts? |
I covered the fuse and tail feathers in a long day including the pinked tapes, one more for spraying up to top coat and one day for top coat One wing took a day to complete up to the tapes (included ribstitching) and the first coat of poly brush. the next day was two more coats polybrush sprayed on, 3 coats silver and two coats polytone.. All depends on how complex a paint scheme you are going with. You can spend alot of time masking at various stages. Another thing to consider. I see alot of guys loading the paint on tillthe weave of the fabric can no longer be seen. This adds ALOT of extra weight and is not needed. If you want a super smooth shiny finish, it was a bad choise to go with a rag covered plane..Just my .02 and you get what you pay for..
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
dosmythe(at)cox.net Guest
Posted: Fri Jun 29, 2007 3:21 pm Post subject: Pre Cover and Finish Thoughts? |
I would choose a bright white color for the entire aircraft and use other
colors for accent stripes etc. A dark color Poly Fiber fabric "can" shrink
during hot outside temps. Been there and done that.
Don Smythe
Lynn Matteson
Posted: Fri Jun 29, 2007 4:00 pm Post subject: Pre Cover and Finish Thoughts? |
I went the other way...a little too stingy with the polytone paint
(or maybe because it was 12 year-old paint) and the edges of my plane
are starting to fade.
My advice is to give it a little more paint and eat a few less pounds
of food...you'll be healthier and the plane will look better...but
like Leonard says, not to excess.
Lynn Matteson
flying w/350+ hrs
On Jun 29, 2007, at 5:31 PM, akflyer wrote:
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
95% complete
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Fri Jun 29, 2007 5:58 pm Post subject: Pre Cover and Finish Thoughts? |
Wiring... It is easier to secure wiring in place before doing the covering. Make sure all the flight controls are operating properly and then remove only what has to be removed for covering. If you decided to inhibit your frame ( the 4130 tubes) the time to do it is before the covering process. Primary temporary fitting of seats will make the permanent installation easier if it has been installed then removed before the covering.
All in all, just about anything you can do before the covering process can be done after only with a lot more four letter 50 cent penalty words.
[img]cid:864595401(at)30062007-0D6D[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
19.77 KB |
681 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Fri Jun 29, 2007 6:20 pm Post subject: Pre Cover and Finish Thoughts? |
You're dead right on that one don... What could be worse if the cloth was
fully shrunk is the possibility of over heating it in the strong sunlight
with dark colours.
Noel
[quote] --
Kitfox III-A
Float Flyr
Posted: Fri Jun 29, 2007 6:31 pm Post subject: Pre Cover and Finish Thoughts? |
I can't help to wonder if any one has flown their plane with just the poly
spray... It should reflect the heat of the sun and be lighter than anything
else.
Noel
[quote] --
Kitfox III-A
7suds(at)Chartermi.net Guest
Posted: Sat Jun 30, 2007 6:08 am Post subject: Pre Cover and Finish Thoughts? |
Andy,
You have been getting a lot of great advise. A few other things to think of,
A good cover and finish job will easily last 20+ years, so do not short cut
using the right amount of materials or putting the extra time in to get the
results you want, you will be looking at it a long time (And so will
everyone else). You will have to decide what is most important to you in the
finish, light weight, smooth finish, quick build, and choose the finish
materials and color scheme that fits. Simple things in the end make a huge
difference, like making sure tapes are straight and the ends are clean cut,
ironing down tape edges continually, rounding open ends of tapes, if this is
your first cover keep the scheme simple and clean, take the time to draw and
color out the sceme on paper (I used the 3 view drawing in the plans and
blew them up then used them to draw and color different schemes) A few
things I like to do is start wet sanding after 2nd coat of silver, use a
bright white as a base for everything and finish buff the final color.
Have fun,
Lloyd
Fox 5 912
UP Mi.
Rebuild Project
(do not archive)
| Quote: | suggestions. Thanks.
Andy Fultz
STRATUS EA-81
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Sat Jun 30, 2007 6:45 am Post subject: Re: Pre Cover and Finish Thoughts? |
| Quote: | Are there any, &(^%(&^%., I wish I had done
that before I covered, items I need to make sure I have done. |
Get plenty of inspection hole covers, paint them, and put them where you can find them in a couple years.
When trimming the fabric along the top and bottom of the fuselage be careful to trim close enough so that the two inch finish tape will overlap properly. If you haven't covered one before this can slip by you until you put the tapes on then wish you had cut it closer.
Bias finish tapes for the tail curves. http://polyfiber.com/products/finishingtapes.htm
_________________ Tom Jones
Classic IV
Ellensburg, WA |
kitfox(at)ida.net Guest
Posted: Sat Jun 30, 2007 11:10 am Post subject: Pre Cover and Finish Thoughts? |
Thanks guys for the many comments and suggestions you have offered. I THINK
I have done about all I can do in preparation for the covering process. I
have one more wire to run and everything I can think of has at least been
prefit and removed or left in place if it won't interfere with the covering.
I do believe I have about run out of excuses to go ahead and get it done.
If anything else comes to mind I'm still listening. Thanks again.
Andy Fultz
smokey_bear_40220(at)yaho Guest
Posted: Sat Jun 30, 2007 12:42 pm Post subject: Pre Cover and Finish Thoughts? |
There was a plane known as the "Gray Ghost" a few
years ago. Don S. probably knows it best. I know it
was a bit hard to see on a cloudy day when it quietly
slipped out of OSH. The Soob sounded like an electric
motor and the plane earned its name by sight and
sound.
If you want to be seen though, paint it to be seen.
Kurt S.
S-5/NSI turbo
--- Noel Loveys <noelloveys(at)yahoo.ca> wrote:
| Quote: | I can't help to wonder if any one has flown their
be lighter than anything else.
Noel
Expecting? Get great news right away with email Auto-Check.
Try the Yahoo! Mail Beta.
Posted: Sat Jun 30, 2007 12:47 pm Post subject: Pre Cover and Finish Thoughts? |
--- Andy Fultz <andynfultz(at)bellsouth.net> wrote:
| Quote: | Good afternoon guys. I'm about to embark on what I
cover and paint my project.......
Andy Fultz
Hi Andy,
Don't know the particulars of your plane, but make
sure you provide access to everything for maintenance
before you cover.
On my S-5 I missed using blind nuts on a few places
like the baggage floor and rudder peddle mounts. Much
harder to work on once covered. To remove the rudder
peddles, I needed to remove the firewall and
everything on it! Check for stuff like that first.
Not everything is best done by the plans.
Kurt S.
S-5/NSI turbo
Get the free Yahoo! toolbar and rest assured with the added security of spyware protection.
http://new.toolbar.yahoo.com/toolbar/features/norton/index.php
lcfitt(at)sbcglobal.net Guest
Posted: Sat Jun 30, 2007 2:04 pm Post subject: Pre Cover and Finish Thoughts? |
Can't agree more with Kurt. In the group that flys the back country
togethere there are all sorts of colors. The least visible is the silver
with blue sunburst on the wings model IV. Then, in my opinion comes white
with yellow the most visible. The silver airplane is visible above the
horizon and gone below - sometimes within 100 yards unless included in a
regular sweep. Take your eyes off for a minute and gone again.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL Warp
1998 850 hrs.
Michel
Posted: Sat Jun 30, 2007 2:25 pm Post subject: Pre Cover and Finish Thoughts? |
On Jul 1, 2007, at 12:03 AM, Lowell Fitt wrote:
| Quote: | Then, in my opinion comes white with yellow the most visible.
Lowell and Kurt, I think I read somewhere that the US air force has
decided that black was the best visible colour for an aircraft during
daytime. Can you confirm that or have I just been dreaming?
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
_________________ Kitfox 3 - Jabiru 2200 |
davestapa
Joined: 13 Mar 2007 Posts: 30 Location: Woodstock, GA
Posted: Sat Jun 30, 2007 2:56 pm Post subject: Pre Cover and Finish Thoughts? |
Andy, I decided that on my 5 it would be difficult to install the
outboard seat belt bolts without pushing fabric out more than I wanted.
So I put a little epoxy on the bolt heads and installed before covering.
Did the same for the tailwheel bolt. Glad I did. Much easier to deal with
now.
C. David Estapa
Woodstock, Georgia
S5TD 912S Warp Drive
Phase 1 Testing
> Andy Fultz
_________________ C. David Estapa
Woodstock, GA
S5TD N97DE |
Posted: Sat Jun 30, 2007 4:31 pm Post subject: Pre Cover and Finish Thoughts? |
Michel, May be true, but I have no knowledge of it. One more thing on
color. When flying in a group some sort of second color highlight is
helpful. Occasionally we will do a roll call sort of thing and if I report
I am off Larry's wing or I can identify Mark's location it helps the others
know the flight's spread and it helps keep the adrenalin under control when
we know generally where we all are. Mark is white with two broad red
stripes fore and aft mid wing. Wray is yellow with a blue stripe on the
fuselage and blue wingtips, Hal is white with green wing tips etc.
Lowell Fitt
Cameron Park, CA
1998 850 hrs.
Fox5flyer Guest
Posted: Sat Jun 30, 2007 6:08 pm Post subject: Pre Cover and Finish Thoughts? |
Kurt, I believe the Gray Ghost was our late Mike Harter with a Model IV/Subaru who lost his life out west several years ago when he got trapped in a canyon he couldn't climb out of.
Somebody please correct me if I'm wrong about this.
Deke
S5/NSI Subaru/CAP
Northeast Michigan
On Sat, 30 Jun 2007 13:41:21 -0700 (PDT), kurt schrader <smokey_bear_40220(at)yahoo.com> wrote:
sound.
Kurt S.
S-5/NSI turbo
> Noel
henrysfork1(at)msn.com Guest
Posted: Sat Jun 30, 2007 7:08 pm Post subject: Pre Cover and Finish Thoughts? |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> No doubt.
