Paul Petty
Posted: Tue Jul 03, 2007 10:39 am Post subject: Kolb pre-flight check list |
Can we start a thread on this subject? I would like to know what items you guys check and in what order. Right now we look over EVERYTHING! And are prbobably over looking something. Need some standards.
_________________ Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp |
dhkey(at)msn.com Guest
Posted: Tue Jul 03, 2007 11:22 am Post subject: Kolb pre-flight check list |
I'm going to add "Check Dennis Line" to my list. I made a line on my oil cap
that lines up with the container when the cap is tight. It should help
except if it's 360 degrees off.
| Quote: | From: "Paul Petty" <paulpetty(at)myway.com>
Reply-To: kolb-list(at)matronics.com
Subject: Kolb pre-flight check list
Date: Tue, 3 Jul 2007 11:39:20 -0700
Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp
http://forums.matronics.com/viewtopic.php?p=122034#122034
a58r(at)verizon.net Guest
Posted: Tue Jul 03, 2007 11:58 am Post subject: Kolb pre-flight check list |
yeah, I know...he's gonna spout some old GA stuff!
But regarding oil caps...I've had several GAs, both with small chains
on oil caps, and without The without one came off between JAX and
TPA. How did I know? Oil all over windscreen, oil temp increasing,
oil pressure heading for zero. Made straight in TPA honking 7700.
The fix; a pc of chain secured to lg screw-type hose clamp, other end
to small hole in edge of cap.
regards,
Bob N. FireFly 070 Old Kolb
planecrazzzy Guest
Posted: Tue Jul 03, 2007 12:48 pm Post subject: Re: Kolb pre-flight check list |
Hey Paul,
Dig around in the archives....We did a thread on this a
couple of years ago....There's some good stuff in there....
What "I" found out was , because people have stuff that "I" don't....
and "I" have stuff they didn't.... I had to use the info to make a
custom fit for "My" bird....You'll probly need to do the same...
Gotta Fly...
Mike & "Jaz" in MN
