Leaking aluminum fuel tank
Jim Shumaker
PostPosted: Sat Feb 11, 2006 10:24 pm    Post subject: Leaking aluminum fuel tank Reply with quote
Hi Lowell
I always enjoy reading your posts. You have excellent advise based
on sound experiance.
I just discovered that one of my fuel tanks is leaking from the top.
It is not from the filler neck so must be a pinhole from another part
of the tank. Do I remember correctly that you also had som leaking in
your tanks? Did you recream them? Did that work? Did you remove the
tank or just slosh the whole wing?
Thanks for the help.
Jim Shumaker
Jim Shumaker
