Giovanni Day
Posted: Sun Jul 08, 2007 7:37 pm Post subject: Static port trouble |
I put my static port in the back just in front of the tail on the pilot side. My vertical speed reads that I am descending all the time and the airspeed reads low. I remove the static and they get better but the vertical speed is dampened for some reason. The air speed is not far off with the cockpit pressure. Where are most of you getting your static air?
_________________ _______________________________________
Giovanni Day
Model 4 speedster 912 |
lcfitt(at)sbcglobal.net Guest
Posted: Sun Jul 08, 2007 9:01 pm Post subject: Static port trouble |
Giovani,
My static port is essentially where yours is - per the Skystar bulletin at
the time. My airspeed is pretty accurate, but runs lower than friends I fly
with. I don't find it a problem as all the speeds I use - approach, stall,
etc are relative to what the ASI reads error and all. There is a small
screw on the face of the VSI that I can set to zero when straight and level.
I adjusted it a time or two by necessity.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL Warp
1998 870 hrs.
Michel
Posted: Sun Jul 08, 2007 11:08 pm Post subject: Static port trouble |
Quote: | From: Giovanni Day [thedays(at)mchsi.com]
What where are most of you getting your static air?
Hello Giovanni,
As Lowell says, your static port position is what Skystar (and Denney, before) recommended. I have mine at the same place although I read an average of 5 MPH higher speed. My VVI is just fine and I have a problem to understand how yours is showing all the time a descent. If I am not mistaking, the VVI is a "bleeding" instrument, i.e. it shows a change in pressure that resets with time when the pressure become constant. If you show a constant descent, it means that it is constantly changing pressure ... which is impossible. So I don't think your static port is the cause of your "constant descent" but maybe your instrument needs calibrating.
Cheers,
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
l.morris(at)tx.rr.com Guest
Posted: Mon Jul 09, 2007 5:52 am Post subject: Static port trouble |
I installed a pitot/static tube (Aircrraft Spruce $15) with is suppose to do away with those problems.---Leon Morris/Classic 4/50%/Flower Mound,TX Giovanni Day <thedays(at)mchsi.com> wrote:
Quote: |
I put my static port in the back just in front of the tail on the pilot side. My vertical speed reads that I am descending all the time and the airspeed reads low. I remove the static and they get better but the vertical speed is dampened for some reason. The air speed is not far off with the cockpit pressure. What where are most of you getting your static air?
Giovanni Day
http://forums.matronics.com/viewtopic.php?p=122801#122801
Guy Buchanan
Posted: Mon Jul 09, 2007 6:16 am Post subject: Static port trouble |
At 08:37 PM 7/8/2007, you wrote:
Quote: | What where are most of you getting your static air?
Mine is in your location and my airspeed reads about 10% low. My
altimeter and encoder has been checked by the avionics shop and found
to be satisfactorily accurate so my airspeed error is in the pitot
side. (My pitot is left wing, near the strut outboard fitting, about
6" below and 10" behind the leading edge. It's been checked for leaks
so the problem is position error.)
The "damping" you see in the cockpit mode is likely a fairly well
sealed cockpit slowly bleeding air in and out. (Hard to imagine in a
IV!) Michel and Lowell have already mentioned that the VSI just needs
adjustment. I'm assuming, of course, that the VSI reads low on the
ground, as well.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Float Flyr
Posted: Mon Jul 09, 2007 6:41 am Post subject: Static port trouble |
I have a single port at what is almost the widest part of the plane (just in front of the door) I have considered putting a second port opposite the existing one to balance the static port in a slip.
Only problem with my location is I have to disconnect it every time I want to remove the lower main cowl. ( model III-A)
[img]cid:297034014(at)09072007-12AA[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
Description: |
Filesize: |
19.77 KB |
Viewed: |
446 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Giovanni Day
Posted: Mon Jul 09, 2007 7:15 am Post subject: Re: Static port trouble |
Thanks for the replies.
I believe my problem is that the static port is under a constant pressure. For some reason it is catching air like a pitot tube. I have checked to make sure the pitot and static are not reversed.
I will zero the VSI in level flight and see what it does then. As suggested I will try and not concern myself with the airspeed error as it is a constant error so all my V speeds will be based on indicated not actual. Heck I have a Garmin 296 and it gives a good VSI and ground speed indication but I just wanted to have the VSI close.
My Static port is very thick like an Oreo cookie and I am now concerned this is the problem. I will take a photo and post it this evening for everyones opinion.
Thanks again.
Giovanni Day
Float Flyr
Posted: Mon Jul 09, 2007 11:46 am Post subject: Static port trouble |
If your static and pitot were reversed the ASI would try to read negative... VSI would also try to reverse. I did see one plumbed this way and mentioned it to the guy who couldn't believe he made so simple a mistake.... Luckily he didn't try to fly like that.
Calibrate the VSI on the ground. The best place to know the plane is neither going up or down. Also easier to do than fly the plane and fiddle with a screwdriver at the same time.
[img]cid:848473919(at)09072007-12B1[/img]
Canada
Aerocet 1100s
[quote] --
Description: |
Filesize: |
19.77 KB |
Viewed: |
436 Time(s) |
Kitfox III-A
kirkhull(at)kc.rr.com Guest
Posted: Mon Jul 09, 2007 2:30 pm Post subject: Static port trouble |
If it is reading a constant decent you might have a leak in the case. Disconnect the static line so the inst is just open to the cabin and go flying. If it still shows a constant decent it is a bad unit
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Noel Loveys
Sent: Monday, July 09, 2007 2:42 PM
Subject: RE: Re: Static port trouble
Canada
Aerocet 1100s
> -----Original Message-----
> [mailto:owner-kitfox-list-server(at)matronics.com (owner-kitfox-list-server(at)matronics.com)] On Behalf Of
> Giovanni Day
> Sent: Monday, July 09, 2007 12:46 PM
> To: kitfox-list(at)matronics.com
> Subject: Re: Static port trouble
> --> Kitfox-List message posted by: "Giovanni Day" <thedays(at)mchsi.com>
> are not reversed.
> Thanks again.
> Giovanni Day
> http://forums.matronics.com/viewtopic.php?p=122858#122858
> Kitfox-List http://www.matronics.com/Navigator?Kitfox-List
> bsp; available href="http://forums.matronics.com">http://forums.matronics.com
Description: |
Filesize: |
19.77 KB |
Viewed: |
459 Time(s) |
Giovanni Day
Posted: Mon Jul 09, 2007 2:35 pm Post subject: Re: Static port trouble |
Let me clarify. It reads constant but variable decent when in flight. Not much variation though. If I disconnect the static in flight it reads 0 and only varies about 100 fpm.
Giovanni Day
wingnut
Giovanni Day
Posted: Mon Jul 09, 2007 3:25 pm Post subject: Static port trouble |
--- Giovanni Day <thedays(at)mchsi.com> wrote:
Quote: | You got it. When in flight it consistently give an
600-800 fpm decent. [Embarassed] LOL However when
the airplane is at rest it reads zero.
My VSI also reads a descent in flight. It is adjusted
at the upper limit to get zero on the ground, but
reads 150 ft/min descent when level in flight. Pretty
close compared to yours, but not perfect either.
In your case, I think it may be static problems if
your ASI is off too. It would also read a wrong
altitude, depending on speed, but that is harder to
confirm. If only the VSI is off, it is probably the
gauge. A static fault anywhere in the system should
throw off all gauges that use it.
The static checks performed by inspectors on your
gauges do not account for position error, only gauge
and line quality. Only blowing air over the port will
check for position error.
You might try tapping a small air damn just in front
of your static port. Something 1/4 inch high and an
inch across about 1/2 inch in front of your port.
This will create a boundry layer over the port and
might make a difference. If it does, you can try
different sizes of little damn until you get one just
big enough to give you accuracy over your speed range.
Then perminately install it.
Smallest change you can make, if it is positon error.
I have seen this on several production planes to
correct their system.
Kurt Schrader
S-5/NSI turbo
Florida and Panama
Be a better Globetrotter. Get better travel answers from someone who knows. Yahoo! Answers - Check it out.
http://answers.yahoo.com/dir/?link=list&sid=396545469
Posted: Mon Jul 09, 2007 4:13 pm Post subject: Static port trouble |
List
I replied to Noel off list regarding my reason for adjusting the centering
screw in flight but recent posts suggest a list wide response is
appropriate. I just checked my VSI and it shows a 50 ft per minute descent
sitting in the hanger - thank goodness for concrete floors.
Since I rarely sit in the airplane on the ground looking at needles - engine
instruments excepted, I have found it more useful to have the VSI more
accurate while flying so adjusting it to zero in that invironment works best
for me. It's not really easy to do, but after a tweak or two it satisfies.
I do carry one of the small jewelers screwdrivers in one of the pencil clips
of my kneeboard.
Lowell Fitt
Cameron Park, CA
1998 870 hrs.
I had to adjust mine in flight---
Giovanni Day
Posted: Mon Jul 09, 2007 6:13 pm Post subject: Re: Static port trouble |
I did a little flying this afternoon. Flew with static to ASI only and it was within 3-5 mph of the gps. I have a EIS with alt. an vsi. I rigged a connection of its electronic sensor to the static and it worked properly. I then connected the mechanical vsi (MVSI)and the EIS. The EIS seemed correct when compared to the GPS but the MVSI was way off as usual. I tried adjusting the MVSI and it seemed to improve. When I pulled the power to land after adjusting it, it went crazy. I think I will locate a known good MVSI and see what it reads.
Giovanni Day
Posted: Mon Jul 09, 2007 7:32 pm Post subject: Static port trouble |
Quote: | I did a little flying this afternoon. .... I think I
will locate a known good MVSI and see what it says.
I think you got it narrowed down pretty well.
Kurt S.
Got a little couch potato?
Check out fun summer activities for kids.
http://search.yahoo.com/search?fr=oni_on_mail&p=summer+activities+for+kids&cs=bz
Guy Buchanan
Posted: Mon Jul 09, 2007 8:52 pm Post subject: Static port trouble |
At 03:54 PM 7/9/2007, you wrote:
Quote: | You got it. When in flight it consistently give an 600-800 fpm
decent. [Embarassed] LOL However when the airplane is at rest it reads zero.
I had to go back to my books to confirm how a VSI works, but if I'm
not mistaken you could get this error if you had a leak in the case.
This would allow the low pressure cockpit air to lower the case
pressure constantly, relative to the static port, causing the
appearance of a descent. It's not entirely unlikely; I had a leak in
my altimeter case that took me days to find. I finally found it by
applying a very slight vacuum using a small hand vacuum source, (used
to bleed brakes.) The vacuum would decay over time, indicating a
leak. I then applied the vacuum and ran a bead of thin cyanoacrylate,
(super glue,) where the bezel met the glass. The cyanoacrylate was
ingested into the leak and sealed it.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
jeburke94je(at)hughes.net Guest
Posted: Tue Jul 10, 2007 4:56 am Post subject: Static port trouble |
congrats!!!!!
Posted: Tue Jul 10, 2007 4:59 am Post subject: Static port trouble |
That is correct. A leak in the case will cause it to read a constant
decent. to check this unhook the static line and go flying. If it still
has the same problem then it is not the static port but is most likely a
leak in the case. If I remember correctly the Kitfox will not read
correctly with out a static system hooked up but it should be close.
