Posted: Tue Jul 10, 2007 12:54 pm Post subject: AEX Tiedown - thickness of flange |
Can someone tell me the thickness of the flange on the AEX Tiedown
extrusion? That is, I'm looking for the thickness of the flange that
the bolts go thru. This same part is used on the tail and wing tiedowns
I'm trying to determine the bolt size to use on one of the aileron
brackets with a cushion clamp added.
Thanks in advance.
Bill "working on QB wing and fuse" Watson
