aft CG service letter
Mark.Summers(at)lwbref.co
PostPosted: Sun Feb 12, 2006 8:12 am    Post subject: aft CG service letter Reply with quote
I read in some of the service letters/bulletins that the model 4 KF aft CG
limit had been expanded to 16" from 14.78" [I think]. From what I have read
aft CG was 28% of mean aerodynamic chord[ 51" on kitfox 2]. I guess what I
am asking does anyone know whether this applies to kitfox 1,2,3 etc? I
think mac is the wing measurement leading to trailing edge? Does the
Kitfox 4 have a different wing measurement than a kf2. Thanks Mark
Lynn Matteson
PostPosted: Sun Feb 12, 2006 9:19 am    Post subject: aft CG service letter Reply with quote
This probably won't answer your question, Mark, but let me drop a
couple of numbers that I have come across in building my IV. The
original manual states that the MAC is 51.5" and the later manual,
revised in '03, shows the MAC at 51.1" This could be due to the change
of flaperon hinge brackets, between when my IV was built in '94, and
when the revised manual was done in '03. Does anybody know for
sure...John McBean, are you listening? And of course the MAC is
apparently measured from the leading edge to the trailing edge of the
flaperon, at least it seems that way according to what I can figure out
right now (with my wings folded).
Lynn
On Sunday, February 12, 2006, at 11:09 AM, Mark.Summers(at)lwbref.com
aft CG
read
what I
Lynn
Kitfox IV-Jabiru 2200
N369LM
PostPosted: Sun Feb 12, 2006 5:14 pm    Post subject: aft CG service letter Reply with quote
I have a feeling that the reference mainly to kf 4 aft cg increase is
because the higher max gross 1200lbs on some of the 4's would see a use for
baggage compartment weights increasing the aft cg where the kf 1,2 and 3
didn't have much weight room for baggage anyway. I guess I am trying to
figure out if aft cg less than 16" but more than 14.28" would be dangerous
in a kf2 because after I get through welding on the new tail I may have to
add ballast in the motor mount area to keep my cg under 14.28 and I really
don't want to do that if at all possible. Thanks Mark
jdmcbean(at)cableone.net
PostPosted: Mon Feb 13, 2006 9:09 am    Post subject: aft CG service letter Reply with quote
The Kitfox IV has a different WING then the Model 1, 2 or 3.. although some
3's have used a IV wing.
Fly Safe !!
John & Debra McBean
www.sportplanellc.com
"The Sky is not the Limit... It's a Playground"
