Help - airspeed sensor
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
czech6(at)kellin.net
PostPosted: Sun Feb 12, 2006 9:19 am    Post subject: Help - airspeed sensor Reply with quote
I happen to have those very instruments. You can get a replacement "G" meter
and compass pretty cheap that are better.
Bill
- The Matronics L29-List Email Forum -
http://www.matronics.com/Navigator?L29-List
jorgen.nielsen(at)mweb.co
PostPosted: Sat Feb 18, 2006 2:53 pm    Post subject: Help - airspeed sensor Reply with quote
So folks, no replies on this. No-one have any ideas? Does no-one else
have the type of airspeed indicator with built in mach-meter?
<jorgen.nielsen(at)mweb.co.za>
Has anyone ever had a look at the box that senses airspeed and retracts
the
flaps automatically?
I need to know what the electronic connection looks like (type of plug,
no.
of pins, etc).
On mine this functionality was moved to a new tyoe of air speed indicator
which is now rather scarce (read unobtainable).
PostPosted: Sat Feb 18, 2006 5:52 pm    Post subject: Help - airspeed sensor Reply with quote
Jorgen,
It is located under the glare shield, left front. If you stand in your seat,
lean over the windshield, (as if looking from outside - in) it is on the
left side torwards the lower front of windshield. Yellow like a fuel
pressure sensor. I hope I remembered that correctly.
Bill
Ernie
PostPosted: Sat Feb 18, 2006 5:58 pm    Post subject: Help - airspeed sensor Reply with quote
Bill,
At your age I'm suprised you can remenber left from right Smile
Ernie
On 2/18/06, Bill <czech6(at)kellin.net> wrote:
Jorgen,
Bill
PostPosted: Sat Feb 18, 2006 6:02 pm    Post subject: Help - airspeed sensor Reply with quote
I think I still have the stock airspeed indicator someplace in a box. If you
want it I'll send it.
PostPosted: Sat Feb 18, 2006 6:20 pm    Post subject: Help - airspeed sensor Reply with quote
I sleep on the left. My wife told me so.
Ernie
PostPosted: Sat Feb 18, 2006 8:20 pm    Post subject: Help - airspeed sensor Reply with quote
I'll leave it at that then Smile
Ernie
PostPosted: Sun Feb 19, 2006 10:56 am    Post subject: Help - airspeed sensor Reply with quote
Hi Bill, thanks.
May I dare ask if you or anyone has a schematic / wiring diagram of the box?
My airspeed indicator has 4 wires going into it, have played with a meter on
the indicator and on the wiring, was hoping to find a pressure activated
microswitch set-up. But its not, seems to be a circuit inside. From the
aircraft, 1 connector is earth, the other 3 has dv bus voltage on. SO in
the airspeed indicator there must be some kind of circuit. A friend has
offered to bring an oscilliscope to the aerie so we can try reverse engineer
the logic and get it bypassed.
Jorgen
PostPosted: Sun Feb 19, 2006 11:00 am    Post subject: Help - airspeed sensor Reply with quote
Thanks but I'm OK on that ubless you have the "Special" one.
I have spare original indicator. (but can't use it. Without the right one
with the electrical connection the hydraulics don't work.
PostPosted: Sun Feb 19, 2006 5:34 pm    Post subject: Help - airspeed sensor Reply with quote
We have different airspeed indicators. I only have air hoses; no electric.
roma(at)airmail.net
PostPosted: Sun Feb 19, 2006 6:03 pm    Post subject: Help - airspeed sensor Reply with quote
the mach meter sends the signal that pulls the flaps on my L-29
Colyergreg(at)aol.com
PostPosted: Mon Feb 20, 2006 7:36 am    Post subject: Help - airspeed sensor Reply with quote
Jorgen,
I have the factory mach meter, but I use a F-86 airspeed indicator which
has Knots 50-700 and mach. but it is just static and pitot. the factory
mach meter is attached to the yellow sensor for the flaps up under the left side
of the panel (on the lower inside of the nose wall.)
PostPosted: Mon Feb 20, 2006 10:37 am    Post subject: Help - airspeed sensor Reply with quote
Thanks Greg.
Sounds good. My air speed indicator show indicated airspeed, true airspeed
(or equivalent) and mach number.
The electronics side is curious. I do not have the yellow sensor, that is
now all done by the air speed indocator.
Do you have wiring details for yellow box?
PostPosted: Mon Feb 20, 2006 3:31 pm    Post subject: Help - airspeed sensor Reply with quote
I will look...
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
