Wing Skin Joint
patrick.pulis(at)seagas.c
PostPosted: Wed Jul 18, 2007 2:52 pm    Post subject: Wing Skin Joint Reply with quote
I am about to rivet on my top wing skins and would like to know if anyone applied Proseal to the inboard / outboard wing skin joint to prevent moisture ingress as a result of capillary action?
Feedback would be very much appreciated please.
PATRICK PULIS
RV-10 #40299
Adelaide, South Australia
Tel: (0Cool 8236 6808
Mob: 0418 850 156
Fax: (0Cool 8236 6899
Email: patrick.pulis(at)seagas.com.au
DO NOT ARCHIVE
n8vim(at)arrl.net
PostPosted: Wed Jul 18, 2007 3:01 pm    Post subject: Wing Skin Joint Reply with quote
Nope; I only used Alodine/Primer
-Jim 40384
anyone applied/ Proseal/ to the inboard / outboard wing skin joint to
*/PATRICK PULIS/*
RV-10 #40299
*Tel: (0Cool 8236 6808*
*Mob: 0418 850 156*
*Fax: (0Cool 8236 6899*
*Email: patrick.pulis(at)seagas.com.au*
*DO NOT ARCHIVE*
ericmpmail-rv10(at)yahoo.
PostPosted: Wed Jul 18, 2007 4:23 pm    Post subject: Wing Skin Joint Reply with quote
I used proseal for the bottom fuselage joint (under the spar) for the same reason. If you do use proseal make sure it is a very thin layer.
Eric
