		bhancock(at)worldwidewarb Guest
				 Posted: Fri Jul 13, 2007 6:38 am    Post subject: Prop Strikes and tear downs |
				On Jul 12, 2007, at 11:58 PM, Yak-List Digest Server wrote:
  I heard Carl
 Hays say that if these engines had a prop strike like this - no need
 to worry about the engine and DO NOT tear down to inspect.  Would
 everyone agree?  |
 The bag of worms is opened!
 Carl Hays has a lot of experience with these engines and I respect his opinion.  The other side of this is there is AT LEAST 3 known engine failures after prop strikes.   Yes, wood and composite is softer than metal, but just how soft is a baseball bat swung at full speed, or water at 70 mph, or air at 200 mph?  Point here is just because wood core props are "softer" doesn't mean that they are not strong enough to cause internal damage during a sudden stoppage.
 Here is a related example.  We now have a customer with a Lancair IV-P that had a history two nose gear collapses.  After the first one they tore the engine apart only to find that everything was A-OK.....a "waste of money" right?  Well....we get called in on the job after the second prop strike and the owner tells me "we tore it down after the first one and there was nothing wrong....I was at idle, so I'm sure it's OK...just throw another prop on it and I'll go fly it."  Well, he doesn't have a wife or kids, but I still insisted that we at least do a run out on the crank.  Sure enough, it didn't meet spec.  We sent the engine to Firewall Forward (who turned the engine in 5 working days) and both the crank and case were bad.  Had he "just put another prop on it" and went flying, his engine definitely would have failed....  (As an aside, the plane was being used in an upcoming movie called FAST GLASS....we flew in it and maintained all 8 of the airplanes...it was a kick!)
 Incidentally, the nose gear collapses were a result of improper hardware and improper installation by previous "mechanics" ...a story unto itself.
 I will never figure out why so many of us pilots put out pocket books before our lives.  If there was even a 1 in 100 chance that you were going to have an engine failure, what do you think your significant other or your kids would tell you to do?
 See you at OSH,
 Barry
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Ernie
				 Posted: Tue Jul 17, 2007 7:04 am    Post subject: Re: Prop Strikes and tear downs |
				I'm not sure what kind of engine the Lancair has, but many Continental engines have Nitrited cranks which are stong but as brittle as glass, so yes I would always tear down any flat engine after a prop strike. My old J-58 Bonanza prop suffered a collision with a towbar which was still attached (Dont ask) and when I tore the engine down the crank was cracked.
 That said, the overhaul manual for the Husai engine says in so many words.
 "If the prop strike wasnt a "Sudden Stoppage", and the damage is located more than 3 feet (more or less, I dont remember the exact dimension), from the center axis of the4 hub (about 6 inches in from the wing tip)  then just replace the prop. I've heard of people doing "Run Out" checks on our round engines. This proves nothing. If the engine was idleing, and you landed on grass or sand, and the prop kept turning, and the blades showed no signs of gross impact (missing metal etc) and the bend occurs beyond the manual specs, then you are probably ok to just replace the prop. Otherwise a teardown is warranted.
 Ernie
		rvfltd(at)televar.com Guest
				 Posted: Tue Jul 17, 2007 11:01 am    Post subject: Prop Strikes and tear downs |
				Guys,
 Would you put your wife or children in a aircraft that was "probably"
 OK?  For that matter would you fly it your self?  Next time you take a
 buddy flying tell him/her that "ya it had a prop strike, but it's
 probably OK", and watch the reaction.  If they are smart they will run
 like hell.   After owning one of the major aircraft salvage companies in
 the US for nearly 20 years (Aircraft Salvage and Rebuild Inc) and
 salvaging over 1000 aircraft, I think I have seen nearly every type of
 accident, from hand propping to wind damage, from bad external loads to
 cruising full tilt into a cloud full of mountain.  I have seen prop
 flanges break off,  mag gear shafts break, gears loose teeth, lock pins
 and keepers come loose, cylinders come completely off the engine.  I
 have seen "homemade mods" come loose causing all sorts of havoc, exhaust
 with holes which caused engine fires, the list is long but in most
 instances can be traced back to something we could have prevented if we
 had not put our wallets in front of our good judgment.
 Recently as most of you know I had a engine failure where in all three
 of the planetary gears in the nose case failed and all power was lost.
 This accident was felt by all who inspected the engine to be the result
 of a prop strike somewhere in the aircrafts distance past.   True the
 engine installed on this aircraft came from China "used" but it is no
 different than me buying a stateside aircraft that had had a
 undocumented prop strike in it's past.  If you sell your aircraft what
 is your obligation to the guy who buys it?  Did you note the prop strike
 in the logs so he can make an informed decision?  Most owners hesitate
 to do so because they feel that it lessens the resale value of the
 aircraft, but that's a topic for future posts.   Guy's, we have enough
 problems to worry about without having to worry about rather the engine
 has been damaged internally after a prop strike, so believe me when I
 say that you simply rolling the dice, maybe you will and maybe you
 won't, maybe it will run 5 hours maybe it will run 500 hours.   If you
 have had a prop strike I do not believe that you can honestly look me in
 the eye and tell me that you feel good enough about your engine to load
 your love ones up and go flying.  It always amazes me that when we ARE
 fully insured the prop strikes are always worse than when we ARE NOT
 insured.  Yes, some have gotten away with doing nothing but changing the
 prop but folks, it simply is NOT worth the chance, and money in this
 instance should not be part of the equation, if it is maybe you should
 look again at rather or not you can afford to own this type of
 aircraft.  If you cannot afford to install a fresh engine at the minimum
 send the prop struck engine out for tear down and inspection.  Then put
 the engine on a 5 to 10 hour oil change with oil analysis at each
 change, and watch it like your life depends on it, because it just
 might.
 Always Yakin,
 Doug
 Ernie wrote:
 Ernie
 http://forums.matronics.com/viewtopic.php?p=124349#124349
		f4ffm2(at)adelphia.net Guest
				 Posted: Tue Jul 17, 2007 11:56 am    Post subject: Prop Strikes and tear downs |
				Doug is, as always, a voice of reason and experience...saying things
 to which we should pay attention.
 I recently happened to be looking directly at a CJ when the pilot had
 a "brain fart" and raised the gear lever.  He didn't raise the gear,
 but he certainly lowered the airplane.  To the point; the airplane
 was parked and the engine was at idle....but when the one blade
 struck the ground, the convulsion that the rest of the airplane went
 through gave graphic evidence of the enormous forces that are working
 inside the engine...even at idle.
 Thanks Doug.
 Roger_____________________________________________________________
 On Jul 17, 2007, at 11:57 AM, Doug Sapp wrote:
  Guys,
  "probably" OK?  For that matter would you fly it your self?  Next
  time you take a buddy flying tell him/her that "ya it had a prop
  strike, but it's probably OK", and watch the reaction.  If they are
  smart they will run like hell.   After owning one of the major
  aircraft salvage companies in the US for nearly 20 years (Aircraft
  Salvage and Rebuild Inc) and salvaging over 1000 aircraft, I think
  I have seen nearly every type of accident, from hand propping to
  wind damage, from bad external loads to cruising full tilt into a
  cloud full of mountain.  I have seen prop flanges break off,  mag
  gear shafts break, gears loose teeth, lock pins and keepers come
  loose, cylinders come completely off the engine.  I have seen
  "homemade mods" come loose causing all sorts of havoc, exhaust with
  if we had not put our wallets in front of our good judgment.
  three of the planetary gears in the nose case failed and all power
  was lost.  This accident was felt by all who inspected the engine
  to be the result of a prop strike somewhere in the aircrafts
  distance past.   True the engine installed on this aircraft came
  from China "used" but it is no different than me buying a stateside
  aircraft that had had a undocumented prop strike in it's past.  If
  you sell your aircraft what is your obligation to the guy who buys
  it?  Did you note the prop strike in the logs so he can make an
  informed decision?  Most owners hesitate to do so because they feel
  that it lessens the resale value of the aircraft, but that's a
  topic for future posts.   Guy's, we have enough problems to worry
  about without having to worry about rather the engine has been
  damaged internally after a prop strike, so believe me when I say
  you have had a prop strike I do not believe that you can honestly
  look me in the eye and tell me that you feel good enough about your
  engine to load your love ones up and go flying.  It always amazes
  me that when we ARE fully insured the prop strikes are always worse
  than when we ARE NOT insured.  Yes, some have gotten away with
  doing nothing but changing the prop but folks, it simply is NOT
  worth the chance, and money in this instance should not be part of
  the equation, if it is maybe you should look again at rather or not
  you can afford to own this type of aircraft.  If you cannot afford
  to install a fresh engine at the minimum send the prop struck
  engine out for tear down and inspection.  Then put the engine on a
  5 to 10 hour oil change with oil analysis at each change, and watch
  it like your life depends on it, because it just might.
  Always Yakin,
  Doug
 > many words.
 > Ernie
		Michael Bolton
				 Posted: Wed Jul 18, 2007 6:06 am    Post subject: Prop Strikes and tear downs |
				Wow Roger, I thought I was the only one with a brain like that.  I also have
 a Housai engine sitting in the corner of the hangar, anyone intrested? lol
 Thanks for all of your help Doug
 Michael
