icovey(at)nc.rr.com Guest
Posted: Sat Jul 14, 2007 1:22 am Post subject: Glasair-List Digest: 4 Msgs - 07/13/07 |
The point of balane is not on the hinge line, but slightly aft of the hinge
about 3/5 ths of the way up from the bottom of the rudder. The ideal
balance is to prevent not only "left-and-right" flutter, but also flutter
about a horizontal axis through the rudder.
I used sheet lead in my not yet flying Super II - FT, and had planty of
spare room for the counterweight, even with it shorter (fore and aft) than
called for in the manual.
BJC
| - The Matronics Glasair-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Glasair-List |
Craymondw(at)aol.com Guest
Posted: Sat Jul 14, 2007 8:03 am Post subject: Glasair-List Digest: 4 Msgs - 07/13/07 |
My GL 2S FT has a Hartzel constant speed prop. My plane cruises at 210 mph using 10 gals per hour at 8,000 feet with full throttle. My RPM is 2375. Higher RPM'S actually make the plane fly slower. A friend has a GL 2 FT using a McCauley prop and cruises at 220 MPH.
The lister that has the TD with a 160 hp, fixed pitch appears to be in the speed range for that configuration.
Get a sneak peak of the all-new AOL.com.
s_korney(at)hotmail.com Guest
Posted: Sat Jul 14, 2007 11:22 am Post subject: Glasair-List Digest: 4 Msgs - 07/13/07 |
At 10 gal. per hour your making about 125 to 130 horse power... I guess
that means that we should all be using a McCauley prop... Like your
friend...
Best... Steve
----Original Message Follows----
Reply-To: glasair-list(at)matronics.com
Subject: Re: Glasair-List Digest: 4 Msgs - 07/13/07
Date: Sat, 14 Jul 2007 12:02:40 EDT
using a
************************************** Get a sneak peak of the all-new AOL
at
http://discover.aol.com/memed/aolcom30tour
Don't get caught with egg on your face. Play Chicktionary!
http://club.live.com/chicktionary.aspx?icid=chick_hotmailtextlink2
