dlm46007(at)cox.net Guest
Posted: Sat Jul 14, 2007 10:48 am Post subject: Firewall Forward heads up |
If you are using the IO540 and the quadrant, be advised to adjust the cables
at the throttle quadrant end for maximum length. Also note that when using
the inverted V pattern through the firewall you will be crossing the
throttle and mixture cables as the throttle is right side and the mixture is
left side forward of the firewall. This works to effectively shorten the
cables. It appears that in my case the cables can be effectively lengthened
by about 1 inch but will require about 2 extra hours of labor to remove them
enough to work on the length.
hotwheels
Posted: Mon Jul 16, 2007 11:48 am Post subject: Firewall Forward heads up |
Does anyone have photos of firewall penetration holes required for the
quadrant?
Jay
Time: 11:48:13 AM PST US
Subject: Firewall Forward heads up
cables
using
is
lengthened
them
Sucker-punch spam with award-winning protection.
Try the free Yahoo! Mail Beta.
