		rholder(at)avnet.co.uk Guest
				 Posted: Sat Jul 14, 2007 12:53 pm    Post subject: Europa Tailplane - Mod 73 "new pip pin" |
				 	  | Quote: | 	 		   This is the reason why the instructions make a point of
   not removing any bid/epoxy around the hole on the
  underside, in the event the pip pin ball should not
  open on the underside of the new layup, but instead buy
   a longer pip pin.  Removing bid/epoxy here would
  defeat that secondary retention function of the mod.
 I am going to disagree with this. I think this requirement
 to "buy a bigger pip-pin" is unreasonable.
 Firstly, the amount of bid/resin required to be removed to
 get the pip pin to release its balls is tiny - see how big
 the balls are ! Maybe a ring of 25 thou of resin/bid would
 need to be removed.
 Secondly I understand that the pip pin BLS4R17N is
 somewhat out of fashion and that it and BLS4R07N (much
 shorter) are the only ones readily available.
 BLS4R17N is a 1 3/4 inch pip pin. There are 2 inch pip
 pins available in a different style but with much larger
 heads.
 The other factor is that the BLS4R17N are about £50 each
 from E(2004), so the Mod 73 fix is a few quid in resin and
 maybe an extra £100 plus VAT if a bigger pip pin is
 required (if they can find any).
 It may be that E(2004) can be persuaded to charge only
 cost price for the longer pip pins (around £20 - £25
 maybe). This problem is after all a design problem.
 Hunkering down down to avoid all the flack that will
 probably come my way.
 Richard
 G-OWWW grounded now for 5 weeks
		ami(at)mcfadyean.freeserv Guest
				 Posted: Sat Jul 14, 2007 1:33 pm    Post subject: Europa Tailplane - Mod 73 "new pip pin" |
				Or, for those of us that don't take off the tailplanes (except now every 10
 hours) a bolt and a nut (or wing nut and securing ring)?!
 Duncan McF.
		rlborger(at)mac.com Guest
				 Posted: Sat Jul 14, 2007 5:05 pm    Post subject: Europa Tailplane - Mod 73 "new pip pin" |
				Fellow Europaphiles,
 Richard Holder commented:
 "The other factor is that the BLS4R17N are about 50 each
 maybe an extra 100 plus VAT if a bigger pip pin is
 required (if they can find any)."
 If there is an issue with the cost of replacement pip-pins perhaps I can help.  McMaster-Carr ( http://www.mcmaster.com/ ) on this side of the pond has of ball lock pins in a wide variety of styles, materials, sizes, mechanisms, etc.  It appears that there are a number of pins that would work and are at prices much less than the 50 UKP  Go to the web site and search on "ball lock pins" and see what works for new pins.  Then let me know how many and I'll see if I can work up a deal on pins at a much better price.  Understand, I don't want to take business from E'04, I'd just like to do what I can to reduce the financial impact of these mandatory mods.
  Good building and great flying,
 Bob Borger
 Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
 http://www.europaowners.org/N914XL
 (90%) tail kit done, wings closed, cockpit module installed, pitch system in, landing gear frame in, rudder system in, outrigger mod in, Fuselage Top on, lift/drag/flap pins in, wing incidence set, tie bar in, flap drive in, Mod 70 done.  Baggage bay in.  Flaps & Main Gear complete.  Mod 72 complete.  Instrument panel complete, except for testing.  Rotax 914 installed (for the 3rd time).  Airmaster Prop installed.  Electrical complete, except for testing.  Fuel system complete except for testing.  Working in - 32 Tail, 34 Door Latches & 35 Doors, 37 Interior & Finishing.  Airmaster arrived 29 Sep 05.  Seat arrived from Oregon Aero.  E04 interior kit has arrived and is being installed.
 3705 Lynchburg Dr.
 Corinth, TX  76208
 Home:  940-497-2123
 Cel:  817-992-1117
				 Posted: Sun Jul 15, 2007 5:44 pm    Post subject: Europa Tailplane - Mod 73 "new pip pin" |
				Richard,
 Mea culpa.  Wrong company.   I had to go back and check my e-mails for the right company.  The manufacturer of the pins is Carr-Lane and they are purchased through a company in Fort Worth called RMP Industrial Supply.  I purchased a number of spare pins from them back in January.  They were identical to the pieces provided by Europa.  The price was USD16.25 each.  And this was considered a "custom" length.
 I will forward a copy of the e-mail from RMP.
 It is possible that I could get further reduced price if the order were large enough.
 I'll see if I can find the web page from which I located the supplier.  If I can, I'll pass it along as well.
 Bob Borger
 3705 Lynchburg Dr.
 Corinth, TX  76208
 Home:  940-497-2123
 Cel:  817-992-1117
 On Jul 15, 2007, at 3:13 AM, Richard Holder wrote:
 Bob
 This is a great message thank you.
 I have actually checked the McMaster site and they don't
 seem to have a pip pin equivalent to BLS4R17N.
 I could of course be going blind/stupid
 My requirement is for a pin with a button which is no
 wider at the top than the existing pip pin - around 3/8
 inch - as I have a narrow threaded brass sleeve between
 the skin and the TP4 which has a threaded cover to it to
 keep the rain out. I have no ring in the pip-pin. I have a
 tool (a bit of bent wire), which just fits between the
 brass and the pip pin to allow entry to the hole in the
 pip pin for removal. It is a bit tight and a pip pin with
 a 1/2 inch head would not work, nor any of the t-handled
 pip pins.
 And of course it has to be a locking pip-pin with a button.
 Maybe McMaster have some other pip pins which are not
 shown on the web site; or maybe I am just blind and
 missing the obvious !
 TIA
 Richard
 G-OWWW grounded 5 weeks
