dfultz7(at)earthlink.net Guest
Posted: Mon Jul 16, 2007 5:47 am Post subject: Flap switch |
Can a Cessna flap switch be used instead of the Ray Allan switch for a trim
servo??? If so does someone have a wiring diagram?? Thanks Dale
nuckollsr(at)cox.net Guest
Posted: Mon Jul 16, 2007 7:33 am Post subject: Flap switch |
At 09:46 AM 7/16/2007 -0400, you wrote:
trim servo??? If so does someone have a wiring diagram?? Thanks Dale
Cessna has lots of flap switches. One of them may be
what you're looking for but you can make one really easy
too. See:
http://www.aeroelectric.com/Pictures/Switches/Flap_Switch.jpg
Posted: Mon Jul 16, 2007 8:01 am Post subject: Flap switch |
Thanks Bob,, Now would you have a wiring diagram to wire the switch up ,,
instead of using the rocker switch that came with the servo??? Thanks Dale
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Tue Jul 17, 2007 6:35 am Post subject: Re: Flap switch |
I think what you need is what I sell lots of--the True Servo Conversion for MAC/RACs. TSCMR. This is a teeny module that converts the external position signal that you get from a voltage divider potentiometer or even a bank of push buttons to control a MAC or RAC trim box.
See: http://tinyurl.com/2qo222
These are the parts they left out of the trim box that would have made it a servo. This also solves the problem of how to connect all those tiny trim box wires.
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
phil.merlin(at)skynet.be Guest
Posted: Tue Jul 17, 2007 2:12 pm Post subject: Flap switch |
I have a genuine Cessna 150 switch. I just need to find out if it can be
wired into the system instead of using the supplied switch from Ray Allen
that was with the servo..
Peter Laurence
Posted: Wed Jul 18, 2007 11:13 am Post subject: Flap switch |
Eric the subject is a flap motor not a MAC servo.
Peter Laurence
Neal.George(at)hurlburt.a Guest
Posted: Wed Jul 18, 2007 11:51 am Post subject: Flap switch |
Peter -
If I understand the descriptions...
Eric's TSCMR, when combined with RAC's position sensor (attached to the
flap mechanism), can be configured to approximate the Cessna-style
set-forget flap switch.
Peter Laurence
Conversion
| Quote: | for MAC/RACs. TSCMR. This is a teeny module that converts the external
| Quote: | position signal that you get from a voltage divider potentiometer or
even
| Quote: | a bank of push buttons to control a MAC or RAC trim box.
it
| Quote: | a servo. This also solves the problem of how to connect all those tiny
Posted: Wed Jul 18, 2007 2:47 pm Post subject: Flap switch |
At 06:11 PM 7/17/2007 -0400, you wrote:
be wired into the system instead of using the supplied switch from Ray
Allen that was with the servo..
Cessna had a LOT of different flap controls. Need a photo,
p/n, perhaps a schematic of the system it came out of.
Baring that detail of data, you can send me the switch
and I'll deduce its suitability to task.
jonlaury
Posted: Thu Jul 19, 2007 8:01 am Post subject: Flap switch |
| Quote: | > Eric's TSCMR, when combined with RAC's position sensor (attached to the
> set-forget flap switch. By the time one buys the separate products and wires them together, wouldn't it just be a lot simpler and probably cheaper to just buy an FPS-Plus-nt (http://www.aircraftextras.com/ ) for $200 and plug and play? john |
