for us non-oshkoshers
slyck(at)frontiernet.net
PostPosted: Mon Jul 23, 2007 5:19 am    Post subject: for us non-oshkoshers Reply with quote
All, yesterday was a fine fine day in western NY. Thom Riddle flew
over in his newly acquired FS and joined
up with me and my ladyfriend for a 15 minute trip to a great fly in
breakfast. Very well attended.
Of interest was a huge biplane with a 330hp chev v8 and outboard
motor redrive. We left before I got to hear
it run.
Our Kolbs drew a lot of curiosity seekers. My passenger weighs
somewhere near 120 lbs which brought us
to about 915 gross. It flew well but until some horsepower-tweaking
mods take place to the little suzuki ,
no heavier passengers will climb aboard.
first pic is Thom landing at my strip using the tassel guidance system.
http://picasaweb.google.com/blitzsplyk/NewAlbum72307900AM?
authkey=k4sMXZWAPJw
Michael Sharp
PostPosted: Mon Jul 23, 2007 6:14 am    Post subject: for us non-oshkoshers Reply with quote
Bob,
What kind of tweeks are you going to do? I'd be interested in hearing details. I'm working on a 1.3L zuki and I know some of us would like to hear details of the tweeking of alternative engines...
Mike
Mark III C
Oak Grove MO...
Do not archive...
robert bean <slyck(at)frontiernet.net> wrote:
[quote]--> Kolb-List message posted by: robert bean
it [quote][b]
The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
Mark Twain,
Roughing it' 1886
Mike
PostPosted: Tue Jul 24, 2007 5:42 am    Post subject: for us non-oshkoshers Reply with quote
Mike/all, pardon any delay in my posts as I now use the day old digest.
You will be entirely satisfied with the 1.3 suzuki, a good power
match for a MkIII.
My 1.0 gives adequate performance in solo flight but starts to notice
when the right seat is occupied.
The easy fix is a "no fat chicks" placard.
Going the suzuki route was a matter of curiosity for me, just to see
if would work.
Also some satisfaction contriving the various systems. The
electrical was a total success.
Cooling took some trial and error. Fuel and carb was a LOT of work,
cutting down and
adapting a carb, a lot of tied down run time at various throttle
settings using a meter
and O2 sensor. I'm probably at 90% of optimum now but once getting
it running
nice and reliable you can understand why a guy would give it a rest
and just do some flying.
I have very short runners on the intake and as a result the
vaporization was incomplete.
To compensate I made a water heated jacket to partially wrap the log
section.
It works well providing I wait until the engine is fully warmed up.
I usually finish my preflight
to use up the time. I will try some minor mixture adjustments to see
if it can be improved.
The last item will be an attempt to alter the cam timing. Designed
for a car, the engine has
peak torque at 3800 but peak hp at about 5500. From what I have read
a slight retardation
of the cam gear will shift the torque curve upward. It means taking
some stuff apart which means
down time, so that will wait for the return of winter. I'll probably
scrounge a used gear
to mutilate so I will still have a good one to fall back on.
This year was the new doors which I am delighted with and for a quick
fix in the climb department
I took a little pitch out of the prop.
Good 'nuff for now.
BB
