		Joel
  Joined: 06 Oct 2006 Posts: 57 Location: Bremerton, WA  USA
				 Posted: Sun Jul 08, 2007 5:29 pm    Post subject: Trim failure |
				Yesterday I flew my model 5 to 14,000 feet and was still climbing at better than 200 FPM. My altitude was verified by ATC at 13k on the way up. After a stop at Port Townsend International I returned to my home field to find the nose up trim was not working. Back on the ground I verified that the trim motor would run in the nose down direction to the limit but would not run at all in the nose up direction.  Searchng through the archives I find two likely suspects; the trim switch or the actuator motor armature. I have 50 hours total on the plane. My question is which is more likely to be the culprit?
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Joel Mapes Kitfox 5 912 ULS Aerocomp amphibs |
		wingsdown(at)verizon.net Guest
				 Posted: Sun Jul 08, 2007 6:09 pm    Post subject: Trim failure |
				My belief it is the trim switch. Could be the wiring. I may have a used
 trim switch somewhere. I would just reverse the wiring and see if she
 runs the other direction. There is only one DC motor so if she runs one
 direction it should run the other direction. You can apply 12 volts at
 the trim motor , just switch polarity and see how she runs. It is a jack
 screw driven by a DC motor.
 Rick
		runwayrex(at)juno.com Guest
				 Posted: Sun Jul 08, 2007 6:33 pm    Post subject: Trim failure |
				My guess is that Rick is right...................unless the motor malfunctioned due to lack of oxygen at 14,000 feet!
 Of course, you had your supply, right?
 Rex in Michigan
 912 UL / Warp / Model 3
 -- "Rick" <wingsdown(at)verizon.net> wrote:
 --> Kitfox-List message posted by: "Rick" <wingsdown(at)verizon.net>
 Rick
 -----Original Message-----
 [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Joel
 Sent: Sunday, July 08, 2007 6:29 PM
 Subject: Kitfox-List: Trim failure
 --> Kitfox-List message posted by: "Joel" <foxfloatflyer(at)hotmail.com>
 http://forums.matronics.com/viewtopic.php?p=122781#122781
 3:26 PM
 &nbs================================================nbsp;Use the Matronics List Features Navigator&Archive Search & Download, 7-Day Browse,&nb=========================              - NEW MATRONICS WEB FORUMS -
		fredshiple(at)sbcglobal.n Guest
				 Posted: Sun Jul 08, 2007 6:46 pm    Post subject: Trim failure |
				Rick's pointing you in the right direction with regards to your  probable switch failure, but replace it with a high quality switch as  that switch sees a lot of use cycles. When mine went I used ACS's  momentary double-pole double-throw switch after quizzing Skystar. It's  a bit pricey but it's now lasted 3 years (only got 6 months with the  first one).
   Fred
		dan(at)azshowersolutions. Guest
				 Posted: Sun Jul 08, 2007 7:05 pm    Post subject: Trim failure |
				This thread has generated a question for anyone that has their trim switch in a Ray Allen (MAK) stick grip. I am still building and this is where I am planning to stick mine. Has anyone put the Ray Allen trim switch (on the stick grip) through a time tested ringer?
   Dan B
   Mesa, AZ
   KF IV, 912s
 Fred Shiple <fredshiple(at)sbcglobal.net> wrote:
   [quote]Rick's pointing you in the right direction with regards to your probable switch failure, but replace it with a high quality switch as that switch sees a lot of use cycles. When mine went I used ACS's momentary double-pole double-throw switch after quizzing Skystar. It's a bit pricey but it's now lasted 3 years (only got 6 months with the first one).
 Fred
 [quote][b]    [quote][b]
		SOURDOSTAN(at)aol.com Guest
				 Posted: Sun Jul 08, 2007 7:26 pm    Post subject: Trim failure |
				I have a MAC trim switch on my stick--has been faithful for 1180 hours.   I wouldn't have my trim switch anywhere else--great on final!
  Stan Specht
 Kitfox Model IV Speedster "Columbine"
 Denver, Colorado
 See what's free at AOL.com.
		n981ms(at)yahoo.com Guest
				 Posted: Mon Jul 09, 2007 3:47 am    Post subject: Trim failure |
				Mine did it too.  The Eaton switch that came with my kit and that I still use can be disassembled (careful,  small parts inside) and the contacts cleaned to fix the problem.
   Maxwell
   S6 TD IO240
 Joel <foxfloatflyer(at)hotmail.com> wrote:
   [quote]--> Kitfox-List message posted by: "Joel"
 Yesterday I flew my model 5 to 14,000 feet and was still climbing at better than 200 FPM. My altitude was verified by ATC at 13k on the way up. After a stop at Port Townsend International I returned to my home field to find the nose up trim was not working. Back on the ground I verified that the trim motor would run in the nose down direction to the limit but would not run at all in the nose up direction. Searchng through the archives I find two likely suspects;       Fussy? Opinionated? Impossible to please? Perfect.  [url=http://us.rd.yahoo.com/evt=48516/*http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7 ]Join Yahoo!'s user panel[/url] and lay it on us.  [quote][b]
		kitfoxmike
				 Posted: Mon Jul 09, 2007 5:25 am    Post subject: Re: Trim failure |
				Sounds like it's your switch, I would just buy a new one and move on.
 As far as the ray allen, if you are using the grip with 4 buttons on top, I like mine only for the up trim, I have it on the button to the back, I end up using the  button on the dash for the down, sure the one on the stick is hooked up, but it takes a bit of stretching to get the thumb to the down button.  This is probably because the control stick is bent, and the normal possision of the stick when flying is a bit forward angled. As far as durability, no problem with mine and I have about 600 hrs on this setup.  I did have problems with there relay deck, on the second one I wrapped it in bubble wrap and then stuck it on the back of the panel. seems to be working fine now.  Of course when I do touches I just leave the trim in one spot throughout the pattern work.
		n85ae
				 Posted: Mon Jul 09, 2007 5:37 am    Post subject: Re: Trim failure |
				My vote is the Armature. Mine failed that way, and when you take it apart
 and see how cruddy those things get inside, you'll be just like me and
 cleaning it every other year or so just for peace of mind.
 Jeff Hays
 Series 5, IO-240B
		m4785(at)bellsouth.net Guest
				 Posted: Fri Jul 20, 2007 11:18 am    Post subject: Trim failure |
				testing my email...thanks mark
  Date: 2007/07/08 Sun PM 11:25:54 EDT
  Subject: Re: Trim failure
  Stan Specht
  Denver, Colorado
  ************************************** See what's free at http://www.aol.com.
				 Posted: Sat Jul 21, 2007 2:47 am    Post subject: Trim failure |
				hI Stan
  I also have the same setup mac/ray allen servo with the trim buttons on my stick,but I had a problem last week with my system and was wondering if you or anyone else has had a simular problem...
   After flying for a couple of hrs I landed at a public airstrip and was out of my fox for an hr,when I started up and taxied to the runway for takeoff I noticed my trim light position was not coming on,after getting out and inspecting my trim tab I found it stuck in the full down trim position,after pulling the servo apart I found that one of the nylon gears had come out of position,I realligned the gear and put the servo back together.The trim sys seems to work ok again..so far....,I  trying to figure out what caused this, did someone play with my trim while I was away from my plane and over run the servo,this seems likely due to there were a few people around my plane at this strip and I dont have to have my key or ignition on to work the trim...or ..could it be a short in the wiring somewhere,but would it go to a full down position if it was a short...........Anyways just wondering if any of you guys have had this happen......
  Regards....Mark N61AC
  Stan Specht
  Denver, Colorado
				 Posted: Sat Jul 21, 2007 6:25 pm    Post subject: Trim failure |
				Mark,
 My guess is that someone physically moved your trim
 tab, possibly by walking into it, and popped the gear
 out.  Just a guess.
 Some days I feel that people would bang into my plane
 trying to pick up their cigarette that they dropped
 reaching for the pen knife they were going to use to
 cut a piece of fabric.....
 Hi Stan also!
 Kurt Schrader
 S-5/NSI turbo
 Florida and panama
 --- m4785(at)bellsouth.net wrote:
  	  | Quote: | 	 		  > hI Stan
 Get the Yahoo! toolbar and be alerted to new email wherever you're surfing.
 http://new.toolbar.yahoo.com/toolbar/features/mail/index.php
				 Posted: Sat Jul 21, 2007 6:54 pm    Post subject: Trim failure |
				You got me laughing good there.....and the burn holes in the fabric from the marlboro man...
  I flew today and put the trim in full down position just to see if I could over power the stick...well I could muscle the stick but it would be real hard to land that way......
  thanks mark........oh shit landing
  From: kurt schrader <smokey_bear_40220(at)yahoo.com>
  Date: 2007/07/21 Sat PM 10:24:42 EDT
  Subject: Re: Re: Trim failure
  Mark,
  out.  Just a guess.
  Hi Stan also!
  Kurt Schrader
  S-5/NSI turbo
  Florida and panama
  >> hI Stan
