DIY - In the ear headphones
echristley(at)nc.rr.com
PostPosted: Mon Jul 23, 2007 7:19 pm    Post subject: DIY - In the ear headphones Reply with quote
I've been looking into building a in-the-ear type headset using low-end
earphones, following the example given at
http://www.canardzone.com/members/nickugolini/CuplessHeadet/cupless_headset.htm
I bought the Phillips ANR headphones from Target. I've got Jim Weir's
impedance matching circuit article describing how to use the audio
transformer, so the headphone portion is in the bag.
The hangup is with the microphone. I found some discussions where Jim
said that an amplifier is needed to use an electret element. Well, I
picked up Item# 270-090 from Radio Shack today.
http://www.radioshack.com/product/index.jsp?summary=summary&techSpecs=techSpecs&currentTab=techSpecs&cp=&custRatings=custRatings&features=features&accessories=accessories&productId 62215&support=support&tab=summary
It has a wiring diagram on the back of the package that seems to
indicate that the single transistor amplifier is already built into the
package. I was going to ask if that was in fact what it indicates, and
inquire whether it would work with the RST-443 intercom. Then I got
antsy and just went and tried it. With only two leads, you know I had
to hook it up backwards and feel disappointed for a minute until I
figured out to turn the leads around. Then it was "WOOHOO!!" all the way.
I'm now well on my way to having the equivalent of a $500, in-the-ear
headset, and it's only costing me about $50. (Testing is incomplete,
but others have reported resounding success.)
sportav8r(at)gmail.com
PostPosted: Tue Jul 24, 2007 7:57 am    Post subject: DIY - In the ear headphones Reply with quote
Keep us posted!
Bill B ...satisfied Lightspeed Mach one user but out $400...
On 7/23/07, Ernest Christley < echristley(at)nc.rr.com (echristley(at)nc.rr.com)> wrote:[quote]--> AeroElectric-List message posted by: Ernest Christley < echristley(at)nc.rr.com (echristley(at)nc.rr.com)>
[url=http://www.radioshack.com/product/index.jsp?summary=summary&techSpecs=techSpecs&currentTab=techSpecs&cp=&custRatings=custRatings&features=features&accessories=accessories&productId 62215&support=support&tab=summary] http://www.radioshack.com/product/index.jsp?summary=summary&techSpecs=techSpecs&currentTab=techSpecs&cp=&custRatings=custRatings&features=features&accessories=accessories&productId 62215&support=support&tab=summary [/url]
headset, and it's only costing me about $50. (Testing is incomplete, [quote][b]
jonlaury
PostPosted: Tue Jul 24, 2007 8:39 am    Post subject: DIY - In the ear headphones Reply with quote
Ernest,
Does the ANR portion of the Phillips headphone still function after your tweaking? And how do you suspend the mike?
I am enamored of the Lightspeed Mach One, but if one can home brew the same thing for $50, I might become an electronerd yet!
John
PostPosted: Tue Jul 24, 2007 10:27 am    Post subject: DIY - In the ear headphones Reply with quote
John Burnaby wrote:
Ernest,
your tweaking?
The ANR sits between the plug and the speaker. I've not verified it
yet, but none of the tweaking I'm attempting should affect the ANR
function at all.
Flox to the end of piano wire that wraps around your head. For maximum
clarity, you want to encase the mic in a box with just one tiny hole
directed at your mouth. Basically, you want to block sound from all
directions, except where your voice is coming from. I'm still working
on this part.
rob(at)hyperion-ef.com
PostPosted: Tue Jul 24, 2007 1:13 pm    Post subject: DIY - In the ear headphones Reply with quote
Actually the "tin can with a hole in one end" approach to microphone design
will give you an omnidirectional mic, which although intuitive, is not what
you need. See
http://www.prosoundweb.com/install/spotlight/cardioid/cardioidmics.shtml for
how a unidirectional mic is made.
Best regards,
Rob Housman
Irvine, California
Europa XS Tri-Gear
S/N A070
Airframe complete
PostPosted: Tue Jul 24, 2007 2:46 pm    Post subject: DIY - In the ear headphones Reply with quote
you need. See
Boy, did you save me some rabbit chasing.
I've now got all the pieces working (except the microphone housing), and
I've had to do practically nothing. The Phillps ANR Earbuds come with a
1/4" adapter that will plug directly into the intercom. The sound is
excellent. My intercom is mono, so I have some work to do there, but
there's nothing to do otherwise. I have to add a 3/16" adapter to the
end of the microphone, and I think a small bottle cap and a piece of
foam double-sided tape will make it into a nice cardoid. The piano wire
bends nicely around my ears and the back of my head, and is very
comfortable with a little heatshrink added.
ceengland(at)bellsouth.ne
PostPosted: Tue Jul 24, 2007 4:16 pm    Post subject: DIY - In the ear headphones Reply with quote
Ernest Christley wrote:
<echristley(at)nc.rr.com>
Rob Housman wrote:
> <rob(at)hyperion-ef.com>
> design
> what
> you need. See
> for
As someone else pointed out, a directional mic would be helpful. Also,
building one starting with an omni is a non-trivial task. Buying an
el-cheapo a/c headset or a used one & cannibalizing it for its mic *is*
a trivial task. (You also get the proper mic connector in the bargain.)
One the guys on an ultralite list I monitor is using ANR earbuds under
his regular headset. He reports that noise reduction is really good. Smile
Charlie
PostPosted: Tue Jul 24, 2007 4:27 pm    Post subject: DIY - In the ear headphones Reply with quote
Yeah, maybe, but the rabbit is still hopping along. I pointed you to the
theory but now you have to get the design to agree with theory. The trick
is to calculate the time values in the referenced article so that the sound
from the rear arrives at the front side of the diaphragm in phase with the
sound from the front. The velocity of sound at 30 deg C is 350
meters/second.
Best regards,
Rob Housman
Irvine, California
Europa XS Tri-Gear
S/N A070
Airframe complete
PostPosted: Tue Jul 24, 2007 4:48 pm    Post subject: DIY - In the ear headphones Reply with quote
Charlie England wrote:
<ceengland(at)bellsouth.net>
>> design
>> not what
>> you need. See
>> for
> and I've had to do practically nothing. The Phillps ANR Earbuds come
> with a 1/4" adapter that will plug directly into the intercom. The
> sound is excellent. My intercom is mono, so I have some work to do
> there, but there's nothing to do otherwise. I have to add a 3/16"
> adapter to the end of the microphone, and I think a small bottle cap
> and a piece of foam double-sided tape will make it into a nice
> cardoid. The piano wire bends nicely around my ears and the back of
> my head, and is very comfortable with a little heatshrink added.
Charlie
Well duhhh...
Is it obvious that I waited until after posting to read the link?
PostPosted: Tue Jul 24, 2007 6:29 pm    Post subject: DIY - In the ear headphones Reply with quote
meters/second.
Yeah, that's one way to go about it.
Another method involves my Echelon headset and a pair of calipers 8*)
egs(at)egsavage.com
PostPosted: Sat Jul 28, 2007 6:50 pm    Post subject: DIY - In the ear headphones Reply with quote
Hey Ernest. Looks like you're well along with your project!
I'm not sure what happened, but I see a post I made sometime back to the
EAA1114 list never made it out to the door. Here is a copy of it below..
--Ed
At a recent builder meeting, I had mentioned this project in the Cozy
community to Ernest. But, this can be used by everyone, not just builders...
Here are a couple of people that give instructions on how to make your own
Clarity Aloft headset clone for around $100. Maybe even approaching under $50
now if you pay attention and find deals. And when I say a clone, I mean right
down to the same Comply ear tips that are used with the Clarity Aloft.
Check it out...
Nick Ugolini (the original project)
Drew Chaplin (latest version by Drew)
http://www.cozy1200.com/geeklog/article.php?story 070427102533266
--Ed
Edward G. Savage
egs(at)egsavage.com
This list provided courtesy of Safe Data, Inc.
To leave send an email to eaa1114-request(at)safedataisp.net with the
Keyword LEAVE in the body.
PostPosted: Sun Jul 29, 2007 11:19 am    Post subject: DIY - In the ear headphones Reply with quote
I got the message. What do you think sent me off in a tizzy. "COOL!! I
gotta make me wonna those!", as soon as I saw it.
Edward G. Savage wrote:
<egs(at)egsavage.com>
--Ed
builders...
own
under $50
mean right
Check it out...
--Ed
"Life is not a journey to the grave with the intention of arriving safely in
a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out, with chocolate in one hand and wine in
the other, loudly proclaiming 'WOO HOO What a Ride!'"
--Unknown
