Eugene Zimmerman
Posted: Sun Feb 12, 2006 10:47 am Post subject: [ Eugene Zimmerman ] Linear Actuator info. |
Richard / Richard and fellow Kolbers,
Back at ya with the info on the electric Linear Actuator I'm using
for my flaps.
Electrak 1, model S12-17A8-06
12 VDC, 75 lbs. load rating,
stroke length 6 ",
and it weighs exactly 1.45 lbs.
You can find it here -
http://www.linearactuators.com/PDFs/Catalogs_and_Brochures/
Actuator_Catalog_Industrial_Section.pdf
But also check out ebay item #
4611331619, also 4612266425, and 8035475116
may be of interest to ya.
One caution, not all models have built-in limit switches.
Power Hatch Lift, Linear Actuator, 6 inch extend
On Feb 11, 2006, at 7:44 PM, Richard Pike wrote:
Looks good. Couple questions: How does the radiator work up ahead
of the
engine? I had my radiator in that location for a while, finally
decided
it was acting too much like a spoiler - Biggest problem was if I
got up
to operating temps and couldn't go ahead and take off, it overheated.
Because it was too far from the prop, no airflow. But your radiator
looks bigger than the one I had - comments?
How much does the electric flap actuator weigh?
Richard Pike
MKIII N420P (420ldPoops)
Email List Photo Shares wrote:
> <pictures(at)matronics.com>
> A new Email List Photo Share is available:
> Poster: Eugene Zimmerman <etzim62(at)earthlink.net>
> Lists: Kolb-List,Ultralight-List
> Subject: Kolb Firestar Modifications
> http://www.matronics.com/photoshare/etzim62(at)earthlink.net.
> 02.11.2006/index.html
