flysrv10(at)gmail.com Guest
Posted: Tue Jul 24, 2007 4:20 pm Post subject: GRT, G530W, TT IIVSGV |
I wanted to let everyone know that I have tested the above combination of equipment on a non precision GPS approach and found that the autopilot follows the approach through it's step-downs and practically makes the approach comparable to an ILS.
You will also have the "glideslope" indication on your display and can fly the approach manually, just like an ILS approach.
I am not sure if this happened on the latest GRT software update or if it was the V29e that did it.
Rob Kermanj
