Mount for pitot
toaster73(at)earthlink.ne
PostPosted: Wed Jan 04, 2006 6:56 pm    Post subject: Mount for pitot Reply with quote
Could someone with a gretz mount be so kind as to post the screw hole locations on the gretz pitot mount. What size rectangle/square would it draw if the hole centers were used as the corners of the square.
Chris Lucas
#40072 wings
LloydDR(at)wernerco.com
PostPosted: Wed Jan 04, 2006 7:35 pm    Post subject: Mount for pitot Reply with quote
I have the non- chromed and there are nutplate holes in each corner, so I am assuming you mean the main screw holes
The main plate is 1 and 7/8" by 3"
and the mounting holes are centered in the above rectangle at 1 and 3/8" by 2and 1/2"
Like a rectangle in a rectangle. If you need other measurements let me know
Dan
40269
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris
Sent: Wednesday, January 04, 2006 9:56 PM
Subject: RV10-List: Mount for pitot
LarryRosen(at)comcast.net
PostPosted: Thu Jan 05, 2006 1:27 pm    Post subject: Mount for pitot Reply with quote
Approximately 1 3/8" x 2 1/2"
However, I would not use these dimensions to drill holes in your skins.
Larry Rosen
Chris Lucas
#40072 wings
PostPosted: Thu Jan 05, 2006 4:50 pm    Post subject: Mount for pitot Reply with quote
Thanks!
Chris
#40072
