gascolator
GenGrumpy(at)aol.com
PostPosted: Mon Feb 13, 2006 7:43 pm    Post subject: gascolator Reply with quote
I'm trying to find a gascolator that has remote cable operation for the drain.
Anyone found one that works on the -10 with IO-540?
Tim, what did you use??
grumpy #40404
Tim(at)MyRV10.com
PostPosted: Tue Feb 14, 2006 4:07 am    Post subject: gascolator Reply with quote
From the fuel valve forward, I did everything per-plans. I never
really got any water out of the forward sump on previous planes.
Usually just the wing sumps. Hopefully that will continue.
I guess you can always add it, but I just don't know if it's
worth the effort or not. I suppose it's a bad thing to find out
the hard way though.
Tim Olson -- Flying RV-10
#40170
drain.
grumpy #40404
dlm46007(at)cox.net
PostPosted: Tue Feb 14, 2006 4:31 am    Post subject: gascolator Reply with quote
As an additional reference , early in the life on my 76 Cardinal RG
(purchased December 76) the FAA mandated a gascolator in the engine
compartment. This was in addition to wing sumps and tank sumps below the
forward seats. In 28 years of ownership I never found water anywhere but
wing sumps. So after the first year I stopped draining the below seat sumps
and later I no longer drained the firewall sump. The only benefit the
additional sumps provided were additional Orings to change every few years.
My Glastar has been flying three years without water any where and only wing
sumps.
Over the years I have found significant water only 2 times. Both times the
FBO who fueled the airplane was almost certainly to blame. Another reason to
fuel and wait a few minutes to sump after fueling.
