Air Compressors
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
Ernie
PostPosted: Wed Aug 01, 2007 5:16 pm    Post subject: Air Compressors Reply with quote
For those fo you who are interested in using an on board air compressor. There is a compresor called a "Cornelieous" (spelling is definately not right). It is a 24v air compressor used in many USAF airplanes. They can be found on occasion on E-Bay. They can deliver 3000 PSI and draw about 80 amps. It is a good emergency system. I had it on my airplane but it was burned out by the previous owner. High pressure compressors require a special oil changed regularly. The previous owner didnt follow that maintenance routine.
It was mounted in the old ADF bay in the starboard nose compartment
Ernie
- The Matronics L29-List Email Forum -
http://www.matronics.com/Navigator?L29-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
