noelbou(at)vif.com Guest
Posted: Thu Aug 02, 2007 10:57 am Post subject: Strange fuel related problem .. |
Hello all,
I am a long time lurker and the owner, since 1999, of a 1990 "vintage"
Twinstar MK II .
I had a strange problem today with my "old faitfull" Rotax 503 with
(single) point ignition ... (yes ...)
I started the engine and then walked away a few feet to talk to a friend
(who just bought a gorgeous MK III with 912s) ...
and suddently the engine started to slow down and then stopped
completely after a few second.
.. as if it would have died from fuel starvation ... Would not "take"
any throttle input ... while slowing down ...
So i checked and found that both carbs "cups" where almost empty (!)
So ... i suspected a gas pump problem (mikuni) ... did a few checks ...
checked that the gas thanks were vented properly
(yes they were) and i started again ...
The engine ran roughly probably on 1 cylinder ... stopped and checked
again and this time
only one of the carb cup was empty and the other one normal (full) ..
Then i removed and checked the part that let the gas in the carb (name
?) (needle controlled by float level)
for any debris or clogging ... and found nothing ... reassembled
everything and fired up the engine.
This time it ran fine ... ran it a 6000 RPM on the ground for ~ 1 min
with no problems ...
Stopped it and restarted a few times and did a couple more low and high
RPM run and everything seemed normal ...
So ... i took off , did a couple of circuits in the pattern and then
headed for a mechanically uneventfull but beatifull flight in the
beatifull Montreal surroundings ...
Now, i (and my friend, who previously owned this plane an flew it > 200
hrs) are just puzzled as what could have been the cause of this strange
behaviour ... ???
- Obviously not a gas pump problem as it ran fine for 1 1/2 hour after .
- Not a gas tank venting problem ... or gas filter, pump etc (as all ran
fine for the 1 1/2 flight)
So what could have caused this "trange behaviour" ?
Any hint greatly appreciated ...
Noel Bouchard
Montreal, Canada
Twinstar MK II with Rotax 503
380 Hrs
P.S. This Twinstar MK II is another living proof of the quality of the
Kolb aircrafts ... and Rotax 503 engines.
It now has well over 800 hrs. on the frame and engine. ( i am the 3th
owner) The Rotax 503 has had good maintenance and was fully rebuilt
at ~ 700 Hrs. I myself have cumulated some 380 hours of flight on this
MK II and 503 and experienced only
two small engine problems. One related to water contamination in (my
first) winter, and another due to
a mistake in a new point set installation which caused premature wear
and engine problem on 1 cyl.
In both even, the engine did not stop, but ran on one cylinder and
allowed for easy precaution landings ...
So i can say this plane and engine have been very reliable. Now i may be
lucky
captainron1(at)cox.net Guest
Posted: Thu Aug 02, 2007 6:44 pm Post subject: Strange fuel related problem .. |
I would suspect a Gremlin passing through, or some air in the line.
Ron (Arizona)
---- "Noël Bouchard" <noelbou(at)vif.com> wrote:
Hello all,
Twinstar MK II .
again and this time
behaviour ... ???
Noel Bouchard
Montreal, Canada
380 Hrs
lucky
kugelair.com
gaman(at)att.net Guest
Posted: Fri Aug 03, 2007 9:27 am Post subject: Strange fuel related problem .. |
it only takes the smallest hair to get caught between the fuel inlet or outlet check valves to interfere with the low speed operation of a diaphragm pump.Do you have a paper element filter between the tank and the pump?
Ron <captainron1(at)cox.net> wrote:[quote] --> Kolb-List message posted by: Ron
Ron (Arizona)
---- "Noël Bouchard" wrote:
--> Kolb-List message posted by: =?ISO-8859-1?Q?No=EBl_Bouchard?=
Hello all,
Twinstar MK II .
... as if it would have died from fuel starvation ... Would not "take"
again and this time
behaviour ... ???
Noel Bouchard
Montreal, Canada
380 Hrs
P.S. This Twinstar MK II [quote][b]
