Jab 3300A alternator warning light
gary_eady(at)xtra.co.nz
PostPosted: Fri Aug 03, 2007 12:46 pm    Post subject: Jab 3300A alternator warning light Reply with quote
I was wondering if there is anyone out there who has wired up an alternator
warning light for the 3300A engine and do you have a wiring diagram for it?
My engine has the 2 wire single phase alternator.
Gary Eady
Whangarei, New Zealand
lightningaustralia(at)big
PostPosted: Fri Aug 03, 2007 2:43 pm    Post subject: Jab 3300A alternator warning light Reply with quote
Hi Gary, If using the regulator supplied with your Jab 3300 eng, the green
wire from the 6 terminal connector block can be hooked up to a light to warn
of low voltage from the altenator. Green wire one side of the globe , neg.
to the other side of globe.This info. is in the CD that comes with your
engine.
Regards, Dennis Borchardt, Lightning Aircraft Australia.
PostPosted: Fri Aug 03, 2007 8:10 pm    Post subject: Jab 3300A alternator warning light Reply with quote
Thanks for the info on the regulator. My CD refers to the earlier 3 phase
alternator with no reference to the green wire.
Gary Eady
