Posted: Sun Aug 05, 2007 9:22 am Post subject: Vacuum Regulator adjustment ....?/Mod 74 suitable conditions |
Hi! All you helpful Europaphiles…..
My new Rapco vac Pump (correct direction for a Rotax) doesn’t seem to generate a reading on the vac gauge?
It is turning the gyro’s but still no reading.
Probably the carbon vanes need bedding in ? However in the meantime which way do I turn the regulator adjustment to increase the vacuum?
a) clockwise screw in
OR
b)anticlockwise screw out
I would be obliged for any pointers please.
Further…. Since Mod 74 is structural I’m concerned of the possibility of achieving the best humidity conditions for the resin to cure. Obviously temperatures are OK. However in the short term I have to question the wisdom of disturbing a perfectly serviceable construction to replace it at this time of year in high humidity conditions. Winter time conditions I NEVER HAD A PROBLEM.
Any comments please or is it a case of “shut up and put up”?
Bob Harrison G-PTAG
Robt.C.Harrison
