Europa-List Digest: 9 Msgs - 08/10/07
Fergus Kyle
PostPosted: Sat Aug 11, 2007 5:56 am    Post subject: Europa-List Digest: 9 Msgs - 08/10/07 Reply with quote
Raimo,
''Time: 10:41:45 AM PST US
Subject: Re: BATTERY MASTER SWITCH
Dear Ferg here is my solution.
I divided the electrical consumption in two as follows:
1) starter, trimming devices, stall warning, gear warning,
door warnings, clock, Dynon back-upp charger, burglary-alarm etc.
This is handled by full mechanic main-swithch
which is installed over the glove shelf (it does not
prevent removing the panel, it is light weight, cheap
and solid and it is operated w/o el pwr).
The switch is about similar somebody has installed
to the co-pilots head rest in the case his accu is in the back.
Price was about 15 euros.
I`m interested to know where you got the mechanical switch and
what amperes it will switch….
2) all the rest is handled by small automotive type relay
http://www.biztee.com/Products/2649.html
using about 30 mA. It handles 40A which is enough for me.
I use it by "master switch" in my panels left side.
Price was about 5 euros.
That sounds ideal, too… thanks for the address
- normally # 1 is always open and # 2 is closed
(trim CB must open also separately!).
- when flying both are closed (ON) of course.
- in the case of emergency landing I open # 2 and
leave # 1 closed - so I am still able to start, use trim
and have all the warnings I am used to (and clock is in time!)
- during long (more than two weeks) staying period I open (OFF) both
This was simple, cheap, lightweight, prctical and safe solution for my purposes.
Wishes, Raimo
I`m keen to add about 15 amps for Amateur radio equipment, so
the 40A looks good as well. Perhaps I can find something like that
here. I have to keep some current for 2 fuel pumps for the 914 which complicates it a bit. I am installing a MiniMac computor to run my
software for Nav and position reporting. The position reports are
routed to my home computor so I have a flight log waiting when I come
home, plus wherever it stops enroute is where Search & Rescue look
for my crash……….
Cheers again!
Ferg
raimo.toivio(at)rwm.fi
PostPosted: Mon Aug 13, 2007 1:32 am    Post subject: Europa-List Digest: 9 Msgs - 08/10/07 Reply with quote
,I`m interested to know where you got the mechanical switch and
, > Ferg
Try any automotive spare part shop like
http://www.adita.fi/default.asp?file=101
I Think I hae a modell 1000-0040.
For example rally cars use it for emergency use.
After crash rescue service can switch off all the power.
Mechanical switch is installed outside the car body in that case.
Why not in planes also (I have not)?
Amperes; you can be sure it handles "enough" . I have similar
type switch in my speed boat and no problem to start V8 454 cin.
If you have two accus you can have two channel model - so you
are able to use accu #1 or accu #2 or both of them together.
You use the switch by removable "key", which is usually red.
If the key is in your pocket, it is difficult to start the engine
- that is also extra safety.
Regards, Raimo[b]
