Jab 2200 install question
DanM
PostPosted: Thu Aug 09, 2007 10:00 am    Post subject: Jab 2200 install question Reply with quote
I've installed a 2200 Jab in my Kitfox IV, there's a small fitting coming from the airbox, about 1/8" i.d. My question is, is this fitting suppose to be connected to the carb fitting of the same size with fuel line tubing?. I've looked in my install manuels but can't find out to much about it.
Thanks in advance
Dan Mc Intyre
Kitfox IV
Jabiru 2200 SN 1311 , 59.7 hours
Sensenich 62x46
N443DM
reames(at)frontiernet.net
PostPosted: Thu Aug 09, 2007 10:41 am    Post subject: Jab 2200 install question Reply with quote
Right On Dan, You got it. BA
info(at)jabiru.cl
PostPosted: Thu Aug 09, 2007 5:54 pm    Post subject: Jab 2200 install question Reply with quote
Hi Dan,
yes this fitting coming from the air box should be connected to the carb
fitting of the same size.
Christian Tannen
gaman(at)att.net
PostPosted: Sun Aug 12, 2007 5:51 am    Post subject: Jab 2200 install question Reply with quote
