sam95037(at)yahoo.com Guest
Posted: Tue Nov 13, 2007 2:11 pm Post subject: Custom Instrument Panel Ground Block |
Bob
I'd like to make a custom instrument panel ground
block for my rv8- checked with B&C, they only make the
two sizes, and do not sell the parts. Are the fast on
tabs commercially available?
Sam Ray
Get easy, one-click access to your favorites.
Make Yahoo! your homepage.
http://www.yahoo.com/r/hs
n8zg(at)bellsouth.net Guest
Posted: Tue Nov 13, 2007 2:24 pm Post subject: Custom Instrument Panel Ground Block |
SteinAir has them...
http://www.steinair.com/accessories.htm
Neal
Bob
I'd like to make a custom instrument panel ground block for my rv8- checked
with B&C, they only make the two sizes, and do not sell the parts. Are the
fast on tabs commercially available?
Sam Ray
frank.hinde(at)hp.com Guest
Posted: Tue Nov 13, 2007 3:39 pm Post subject: Custom Instrument Panel Ground Block |
Yes,
Go to Steinair.com he has them for like a buck per strip. Get a piece of
Brass plate and solder one up.
I made a 60 tab ground block for about $5...Brass bolt form the hardware
store.
Frank
nuckolls.bob(at)cox.net Guest
Posted: Wed Nov 14, 2007 7:22 am Post subject: Custom Instrument Panel Ground Block |
At 04:23 PM 11/13/2007 -0600, you wrote:
Neal
Bob
Yes but not easy to find. You COULD consider something like
a D-sub connector soldered to a sheet of thin brass to
accommodate the majority of grounds which are 3A or less
and use screws/ring terminals to tie down the few high
current grounds. See:
http://www.aeroelectric.com/Pictures/Grounding/AGB_V.jpg
http://www.aeroelectric.com/Pictures/Grounding/AVG_RA.jpg
http://www.aeroelectric.com/Pictures/Grounding/Avionics_Bus_3.jpg
You could do a variation on a theme for the firewall
ground block where there is a combination of high-density
wiring for low current grounds and coarser density for
a few high current grounds.
( -Thomas Paine 1776- )
Posted: Wed Nov 14, 2007 7:52 am Post subject: Custom Instrument Panel Ground Block |
I'm looking for the tabs with a pair spacing of 0.26
inch across- the steinair tabs have a larger spacing
for a larger terminal block and are only a single
pair. I've found 3 tab pairs made by Amp in the Tyco
catalog, but nothing like the larger 12 pair sets used
by B&C. I was hoping Bob would know where I can get
these...
Sam Ray
| Quote: | SteinAir has them...
| Quote: | http://www.steinair.com/accessories.htm
Never miss a thing. Make Yahoo your home page.
Posted: Wed Nov 14, 2007 9:02 am Post subject: Custom Instrument Panel Ground Block |
At 07:51 AM 11/14/2007 -0800, you wrote:
these...
When I crafted that product mucho years ago, I
found a reel of paired tabs in an industrial
surplus store. That first real carried us through
a number of years of production. I don't know where
Bill gets them now.
He probably purchases on reels as an industrial
offering by AMP or T&B. I've never seen them in
small quantities/sizes as catalog items.
echristley(at)nc.rr.com Guest
Posted: Wed Nov 14, 2007 10:10 am Post subject: Custom Instrument Panel Ground Block |
<nuckolls.bob(at)cox.net>
> these...
Bill gets them now.
I ordered a handful from Digikey.
Catalog page 341.
http://dkc3.digikey.com/PDF/T073/P0341.pdf
stein(at)steinair.com Guest
Posted: Wed Nov 14, 2007 10:12 am Post subject: Custom Instrument Panel Ground Block |
Hi Sam,
What part of mine are you talking about?
The SA-9900 people pointed you to previously (below) are what you are
wanting - they have five pairs of tabs (10 total) and are spaced exactly
.26" apart.
I think Perhaps you were looking at something else because these are NOT
what you are describing below?!?!
Look again and you'll see they are exactly what you're describing! They are
a whopping $1.00 each, as everyone pretty much noted before.
Cheers,
Stein
[quote]--
