scott(at)randolphs.net Guest
Posted: Tue Feb 14, 2006 3:56 pm Post subject: Z31-B Ground power disconnect? |
Reviewing the diagram of the "piper" style ground power plug in Z-31B it
appears that once external power is applied, the contactor would stay
energized forever (at least until the battery was killed) since the
engergizing current would flow backward through the contactor and through
the solenoid coil. Is there a key point I'm missing or is an interrupt
switch of some kind called for?
Thanks!
nuckollsr(at)cox.net Guest
Posted: Wed Feb 15, 2006 5:28 am Post subject: Z31-B Ground power disconnect? |
At 03:54 PM 2/14/2006 -0800, you wrote:
Yup, it's called the ground power control switch illustrated
in this case as a switch-breaker in the lower left quadrant
of the drawing. If you want to use a miniature push-pull breaker,
then an additional switch is called for . . . or you could use
the breaker itself as the controlling device. It's a VERY low
usage item and I'd have no heartburn about using the breaker
as a switch in this case.
