		rleffler
				 Posted: Sun Aug 19, 2007 1:54 pm    Post subject: Blue Plastic removal |
				I started out removing strips of the blue protective plastic to allow for dimpling and riveting.   I’ve had several people comment that they had some corrosion issues focused under the edges of the blue plastic.   The most recent was from the technical counselor that was just out for my first counselor visit.
 So I guess the debate would be which symptom would be worse after 2-3 year build period,  scratches or minor corrosion.  Since all of these reports have been second hand, I’m looking for feedback from anyone that had any corrosion after the removed the blue plastic at the end of the build.
 Any strong opinions with either option?   Did anyone else find corrosion under the blue plastic when removed?
 Bob
 #40684
  _________________ Bob Leffler
N410BL - Phase I
		egohr1
  Joined: 17 Jan 2006 Posts: 38 Location: Oklahoma City
				 Posted: Sun Aug 19, 2007 2:43 pm    Post subject: Re: Blue Plastic removal |
				Can not speak to the corrosion issue.  I am stripping the blue plastic from the empanage with was finished 2 years ago and it is coming off in small hard to remove pieces.
 I stripped the rest of the airplane as it was built.
  _________________ eric gohr
EGOHR86@alumni.carnegiemellon.edu |
		ron.mcgann(at)baesystems. Guest
				 Posted: Sun Aug 19, 2007 3:06 pm    Post subject: Blue Plastic removal |
				I left the vinyl on the skins in the shed extremes of heat/cold,
 dry/damp for 3+ years.  Corrosion was evident, but limited to only very
 tiny areas at the vinyl edges - not worth a second thought.  The vinyl
 had hardened with age and was a little more difficult to remove, but I
 have heard that slightly heating the vinyl with a heat gun allows it to
 come off more easily
 Cheers,
 Ron
 -187 finishing
		speckter(at)comcast.net Guest
				 Posted: Sun Aug 19, 2007 3:36 pm    Post subject: Blue Plastic removal |
				From my experience with several builds, the bigger issue is the difficulty of removing the plastic after it has been stored for several years.  In one extreme case I had to sand off the plastic with a power sander and z-strip paint remover in order to get it off.  It is true that a heat gun helps, but the longer it is on and the more it is subjected to sunlight, even through windows, the tougher it is to remove.  My solution to the scratch issue is to wrap the part in bubble wrap after it is completed.  That protects against scratches and small blows.
 Gary
 40274
 Wiring OP Tech panel
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
  Sent: Sunday, August 19, 2007 4:53 PM
  To: rv10-list(at)matronics.com; rv-list(at)matronics.com
  Subject: Blue Plastic removal
 Bob
 #40684   	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV10-List  | 	  01234
		cehoffman(at)bellsouth.ne Guest
				 Posted: Sun Aug 19, 2007 4:13 pm    Post subject: Blue Plastic removal |
				I have had more corrosion problems from perspiration dripping on the  aluminum than from any blue plastic that stayed on to protect the skin.
  Cal Hoffman
  40119 (Instrument Panel)
  [quote]   ---
		rvbuilder(at)sausen.net Guest
				 Posted: Sun Aug 19, 2007 5:05 pm    Post subject: Blue Plastic removal |
				I’ll echo what Gary said, it can get to be a bear to get the stuff off after a while.  I also used to do the strips but just didn’t see the point anymore.  Besides, you are going to scratch the hell out of it when you go to paint it anyway.  And any minor filliform or other corrosion will also be removed when you go to sand it.  Better to let it breath in my opinion.
 Michael
 Bob
 #40684  [quote]  ;         - The RV10-List Email Forarch & Download, 7-Day Browse, Chat, FAQ,[/b]_;  --> http://www.matronics.bsp;         - NEW MATRONICS WEB FO; http://forums.matronics.com</================== [b]
		KiloPapa
  Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
				 Posted: Sun Aug 19, 2007 7:14 pm    Post subject: Blue Plastic removal |
				Howdy,  You may find the vinyl coating  difficult to remove after a 2-3 year period.  Here is an excerpt from  "Materials used in RV Airframes (Section 5) Part 1" located in the construction  section of Van's website.
 5M VINYL COATING
 Many of  the alclad parts are supplied with a thin (usually blue) vinyl coating to  prevent scratching during the
 manufacturing of the parts. The vinyl may be  left on during drilling but should be removed for dimpling, priming and
 final  installation. It is possible to remove strips of vinyl along rivet lines with a  soldering iron. Carefully round and
 smooth the tip of the iron so it won’t  scratch the aluminum.
  The adhesive on the vinyl strengthens with age,  so if the coating is left on for more than a few weeks, it may become very  difficult to remove.
 Corrosion has been found under the vinyl in some  instances. If vinyl covered parts
 must be stored for long periods, remove the  vinyl first.
  Kevin
 40494
 tail/empennage
  _________________ Kevin
40494
do not archive |
		rene(at)felker.com Guest
				 Posted: Sun Aug 19, 2007 8:40 pm    Post subject: Blue Plastic removal |
				I just removed mine from the completed fuselage.  The plastic has been on for 1.5 to 2.5 years.  No corrosion and not hard to remove.
 Rene'
 40322
 Fisnish…….paint
 801-721-6080
