nuckollsr(at)cox.net Guest
Posted: Sun Aug 19, 2007 2:20 pm Post subject: Bright star on the horizon - OV protection and anytime contr |
| Quote: | Comments/Questions: Bob - What is the latest wisdom on the crowbar and b-lead
disconnect for the IR alternators? I have read all the Matronics threads,
and it seems that you have withdrawn the Z-24 diagram.
| Quote: | BTW I am a PhD electrical engineer, and I have not seen anyone with the
clarity and good explanations and sheer common sense that you give.
Keep up the good work.
Thank you sir for the kind words and validation of
my efforts.
Here's some background:
http://www.aeroelectric.com/DIY/DIY_Crowbar_OVP_F.pdf
Here's the Z-24 replacement in the works . . .
http://aeroelectric.com/articles/Adapting_IR_Alternators_to_Aircraft.pdf
in the interim, Z-24 is entirely suited to the task as
long as the pilot is aware that the alternator should not
be turned off while under load except when it's mis-behaving
or there is possibility of electrically generated smoke
in the cockpit.
When AEC9004 becomes available, it will drop neatly into
the spot where the crowbar module is used and will allow
any time, any conditions, damage free control of the
stock, automotive IR alternator.
Holler if I can help!
( IF one wishes to be "world class" at )
( anything, what ever you do must be )
( exercised EVERY day . . . )
( R. L. Nuckolls III )
