f.miskelly(at)imperial.ac Guest
Posted: Mon Aug 13, 2007 4:15 am Post subject: Nav/com 'acoustic feedback' |
The KX155 nav/com in my Glastar has 2 problems which may be related.
1. Inserting the headphone jack i have near perfect reception. However, when i insert the microphone jack there is a loud whine suggestive of 'acoustic feedback'. Moving the boom away from my mouth reduces the whine. With a different headset it appears as lots of static noise which again changes with position of the boom. I've changed the aerial, power supply and checked all the earths. It occurs with either mag and when the generator is disconnected. It only happens when the engine is running. The radio's been bench tested and passed as good.
2. Radio reception is good with just the headphone jack inserted. However, insert the microphone jack and reception becomes very poor or disappears completely. I suspect the 'acoustic feedback' is raising the automatic squelch which is cutting off the radio station
Can anyone suggest an explanation and a solution!
Many thanks
Frank
echristley(at)nc.rr.com Guest
Posted: Mon Aug 13, 2007 6:05 am Post subject: Nav/com 'acoustic feedback' |
Miskelly, Francis G wrote:
| Quote: | The KX155 nav/com in my Glastar has 2 problems which may be related.
passed as good.
Many thanks
Frank
Since there is a problem with multiple headset, I would check the jack
first. The symptoms seem to imply some feedback from the mic to the
audio. Look for a short or a broken ground. Beyond that, it would seem
circuitry withing the intercom is fritzed, and it gets much more
complicated.
Posted: Mon Aug 13, 2007 8:01 am Post subject: Nav/com 'acoustic feedback' |
Thanks for your comments Ernest.
I've double-checked all the grounds i could find. Even took the whole harness out (which was new) and had it double-checked. Nothing found.
If its the intercom in the radio why does it not cause the same problem when the engine is off?
It only causes the problem when the engine is running
Kind regards
Frank
From: owner-aeroelectric-list-server(at)matronics.com on behalf of Ernest Christley
Sent: Mon 13/08/2007 15:04
Subject: Re: Nav/com 'acoustic feedback'
passed as good.
Many thanks
Frank
complicated.
mprather(at)spro.net Guest
Posted: Mon Aug 13, 2007 9:03 am Post subject: Nav/com 'acoustic feedback' |
Ernest,
Your response kind of points to what I was thinking.. I don't think the
KX155 has any intercom, but the description of the symptoms seem like an
intercom problem. If so, I wonder if turning off the intercom aleviates
the behavior. If there isn't any intercom, then I might suspect the radio
has a problem. Plugging in the mic shouldn't have any effect until the
PTT circuitry is activated, but then you wouldn't get _any_ reception
(because the transmitter would be active)..
If the problem is related to the intercom, consider trying to find a way
to adjust the mic gain on the intercom.
Matt-
<echristley(at)nc.rr.com>
> passed as good.
> Many thanks
> Frank
complicated.
| Quote: | Thanks for your comments Ernest.
Kind regards
Frank
Where is your squelch set at?
Posted: Mon Aug 13, 2007 11:14 am Post subject: Nav/com 'acoustic feedback' |
Does it help if you cover the mic with your hand (both sides - pull the
muff off)?
I suspect that the input stage of your intercom is being overdriven by the
acoustic noise of the engine.
Matt-
Kind regards
Frank
Christley
> passed as good.
> Many thanks
> Frank
complicated.
Posted: Mon Aug 13, 2007 12:36 pm Post subject: Nav/com 'acoustic feedback' |
Matt
1. When i cover the mic with my hand (muff off) the character of the feedback alters significantly but is not overall reduced. If i move the boom away from my mouth and around to the back of my head then the feedback reduces but doesn't disappear. Its worse (louder) the closer the boom to my mouth. These symptoms occur on both left and right hand headsets
2. My KX155 has an internal intercom. I haven't tried to disconnect it.
3. Plugging in the mic jack should activate the intercom and the transmit on the radio (when PTT pressed)
4. Remember the problem only occurs when the engine is running.
5. Does anyone know how to adjust the mic gain (intercom volume control) on the KX155? Couldn't find this info in the installation manual.
Kind regards
Frank
From: owner-aeroelectric-list-server(at)matronics.com on behalf of Matt Prather
Sent: Mon 13/08/2007 20:12
Subject: RE: Nav/com 'acoustic feedback'
--> AeroElectric-List message posted by: "Matt Prather" <mprather(at)spro.net>
muff off)?
Matt-
Kind regards
Frank
Christley
--> AeroElectric-List message posted by: Ernest Christley
> passed as good.
> Many thanks
> Frank
complicated.
- The AeroElectric-List Email --> http://www.--> http://forums.matronics.com
Posted: Mon Aug 13, 2007 1:32 pm Post subject: Nav/com 'acoustic feedback' |
Interesting.. I wasn't aware that any KX155 has intercom. Okay. I see
the manual says it has 500ohm aux inputs, but don't see any reference to
intercom. We're talking about a Bendix/King KX-155, right? Do you have a
link to a file which describes the feature?
Does the sound vary depending on where your head/headset is sitting, or by
bending the wires around on the headset, or the wires to the jack?
Is the frequency of the whine/feedback dependent on the engine RPM? Or is
it just a steady tone?
I agree with item 3 (assuming an intercom).
Matt-
| Quote: | Matt
headsets
Kind regards
Frank
Prather
muff off)?
Matt-
> Kind regards
> Frank
> ________________________________
> Christley
> To: aeroelectric-list(at)matronics.com
>> passed as good.
>> Many thanks
>> Frank
> complicated.
rjquillin
Posted: Mon Aug 13, 2007 2:16 pm Post subject: Nav/com 'acoustic feedback' |
At 14:29 8/13/2007, you wrote:
| Quote: | Interesting.. I wasn't aware that any KX155 has intercom. Okay. I see
I do find a reference in the IM for a 155A/165A to an intercom level
adjustment.
Is this an A model?
Ron Q
Posted: Mon Aug 13, 2007 3:43 pm Post subject: Nav/com 'acoustic feedback' |
1. The radio is a Bendix/King KX155
2. It is approximately 1 year old. Don't know the model # but could find out
3. It definately has an internal intercom but i've no links to describe it
4. I didn't check whether the sound varied depending on where your head/headset is sitting, or by
bending the wires around on the headset, or the wires to the jack but it occurred with 3 separate headsets and on both pilot and co-pilot outputs. Pretty sure its not a headset problem as same headsets work fine in other planes
5. The noise gets worse with higher engine RPM but is very obvious even at 1000 RPM. The character doesn't change - just its loudness
Many thanks
Frank
Sent: Mon 13/08/2007 22:29
Matt-
| Quote: | Matt
headsets
Kind regards
Frank
Prather
muff off)?
Matt-
> Kind regards
> Frank
> Christley
>> passed as good.
>> Many thanks
>> Frank
> complicated.
Posted: Tue Aug 14, 2007 6:42 am Post subject: Nav/com 'acoustic feedback' |
The squelch is set to off. Pulling out the volume control knob takes off the squelch. When i leave the squelch on there is virtually no radio reception at all.
- Frank
Sent: Mon 13/08/2007 17:57
Kind regards
Frank
Posted: Wed Aug 15, 2007 2:31 pm Post subject: Nav/com 'acoustic feedback' |
I'm still not sure whether it's electrical noise or acoustic noise - since
covering the mic has some effect on the behavior. If it were just
acoustic, covering the mic should stop the noise. More questions:
- Is the acoustic squelch on the intercom adjustable? Can you set the
threshold higher? Maybe pulling out the volume knob and turning it
adjusts that? Or is it dynamic/smart adjusting?
- What kind of engine is it?
- Does it have separate ignition systems? Can you turn one off at a time
(to help isolate electrical noise)?
- Can you turn the alternator off with the engine running?
- You probably answered this before, but with the engine off, does the
intercom appear to work properly? Speaking in the mic on one headset
yields sound coming from the other headset - using the radio sidetone?
- Are you able to transmit/receiver properly when the engine is off?
- Are the mic leads made with shielded wire?
- Do other aspects of the electrical system all appear to function
normally - bus voltage, nav signals, etc?
Bob often recommends powering from a separate battery the piece(s) of
equipment that are involved in the problem. A couple of lantern batteries
could be used to power the radio while the engine is running.. If that
has any effect on the noise, it indicates that the problem is conducted to
the radio via the power bus.
What would be slick for this kind of online debug process would be to have
an online spreadsheet or form which could be used to document the problem,
behaviors, and the things that have been tried in order to fix it.. Have
to ponder that a bit.
Matt-
| Quote: | 1. The radio is a Bendix/King KX155
out
planes
Many thanks
Frank
Prather
Matt-
> Matt
> the
> headsets
> transmit
> Kind regards
> Frank
> Prather
> muff off)?
> the
> Regards,
> Matt-
>> Kind regards
>> Frank
>> Christley
>>> passed as good.
>>> Many thanks
>>> Frank
>> seem
>> complicated.
Posted: Thu Aug 16, 2007 4:33 am Post subject: Nav/com 'acoustic feedback' |
Thanks Matt
Answers (in italics) to your questions below
- Frank
Sent: Wed 15/08/2007 23:27
I suspect its not acoustic as it doesn't affect my handheld ICOM and the a/c is not that noisy
I don't know how to adjust the intercom volume. I presume it is adjustible. Pulling out the volume knob takes off the automatic squelch. There is no obvious knob to adjust the intercom vol.
- What kind of engine is it? Its a Lycoming 0-320 with 150hp
(to help isolate electrical noise)? It has 2 mags and i've tried both separately - no effect
- Can you turn the alternator off with the engine running? Turning off alternator - no effect
With the engine off the radio is perfect. No intercom problems. Perfect reception and transmit
- Are the mic leads made with shielded wire? Mic leads are not shielded. They are 2 twisted wires
normally - bus voltage, nav signals, etc? All other parts of electrics are fine
the radio via the power bus. Tried that from a separate 12V battery - no effect
I've changed the antenna, power supply, headsets, earthed everything possible and checked all the earths. The problem of feedback only occurs when i plug in the mic jack when the engine is running. I have a handheld ICOM which uses the same power supply and aerial yet it works perfectly. It has no intercom.
I plan to disconnect the intercom this weekend to see whether the problem disappears.
Matt-
out
planes
Many thanks
Frank
Prather
Matt-
> Matt
> the
> headsets
> transmit
> Kind regards
> Frank
> Prather
> muff off)?
> the
> Regards,
> Matt-
>> Kind regards
>> Frank
>> Christley
>>> passed as good.
>>> Many thanks
>>> Frank
>> seem
>> complicated.
<http://www.matronics.com/Navigator?AeroElectric-List>
