ronschreck
Joined: 04 Aug 2006 Posts: 192 Location: Gold Hill Airpark, NC (NC25)
Posted: Thu Aug 16, 2007 1:16 pm Post subject: Loss of essential bus |
I have an intermittent loss of the essential bus in my RV-8. I have wired it similar to Bob's Z-11 Generic Light Aircraft Electrical System except that I have added an aux battery as depicted in his Z-30 diagram, as I have dual electronic ignition. I suspect that the problem is in the diode that prevents reverse current when the essential bus alternate feed switch is turned on. My question: Is it possible that this diode is defective and could cause intermittent loss of the essential bus? When it occurs, the current is almost immediately restored without any action on my part, but it does cause all the avionics to reboot. It occurs without warning and I cannot trust it in IFR conditions. Any suggestions? Thanks.
Ron Schreck
RV-8, "Miss Izzy"
nuckollsr(at)cox.net Guest
Posted: Sat Aug 18, 2007 7:14 am Post subject: Loss of essential bus |
At 05:14 PM 8/16/2007 -0300, you wrote:
| Quote: | I have an intermittent loss of the essential bus in my RV-8. I have wired
I've never seen a diode go intermittently open . . .
but that doesn't mean it absolutely cannot happen
however it's hard to imagine how.
| Quote: | When it occurs, the current is almost immediately restored without any
I'd suspect a loose connection first. There's not
many. Check them all. As long as your crawling around
under there . . . you could consider replacing both
wires (fresh crimps) and a new diode. In any case,
the problem cannot be terribly difficult, it doesn't
involved much hardware.
